Tip & How-To about Audio Players & Recorders
Setting MP3 Backgrounds or changing them
By going to the settings options and clicking on the background scroll down and choose your background and it sets it up for you.
how can i make a downloaded picture fit into my desktop background?
you can righ click on the image and choose the "set to background" option that if you are using the windows OS. then go into desktop setting, by right click on the desktop (empty space on the screen) and choose personalize and then desktop background. there will be three option to choose from: option one will fit to screen. this is the option you would want to choose. this is for windows vista. but you should get the idea.
Feb 10, 2012 | HP Computers & Internet
how do you change your background on your Coby mp828?
Hi sauerbrood2,
Changing the background is quite simple ,
All you need to do is Go in the settings option and then click on the background and then scroll down and then you can choose the back ground for yourself.
Hope that helps ..:) Let me know in case you have any queries , your feedback would be appreciated.
Sep 12, 2011 | Coby MP828 MP3 Player
how to set the packet data setting for nokia 5310?
  1. Press Menu
  2. Choose Settings and select
  3. Scroll down screen to choose Configuration and select
  4. Scroll down screen to choose Personal config. Settings and select
  5. Now, press Add (visible if you don’t have a previous Personal Setting created) or press the Options button. when you have pressed the Options button, choose Add New. Then you will have several options to choose from.
  6. Now, scroll down and choose the Access Point and select.
  7. Choose option Access point settings and select
  8. Go into Bearer Settings
  9. Now, choose Packet Data Access Point
  10. Now, enter your APN address corresponding to your operator, then press OK
  11. Now, go back to the Personal Configurations Settings menu (press Back 3 times), where you now should be able to see an Access Point (or called My access point) selected.
  12. Now press Options button, and then choose to activate the Access Point.
  13. Now you should be able to access internet.
Aug 10, 2010 | Nokia 5310 Cellular Phone
laptop
Another option is to view the picture you want using the "Windows Picture and Fax Viewer" then right-click on the image and click on "Set as Desktop Background". This should help you have a new background.
Don't forget to rate... Post back if this doesn't work...
Feb 20, 2008 | Dell Inspiron 1501 Notebook
desktop backgrounds
just right click on any picture and choose option set as desktop background
Oct 03, 2007 | HP Compaq Presario Media Center SR1750NX...
282 people viewed this tip
 Grubhead
Grubhead
