Tip & How-To about Computers & Internet
Method to reboot system using CD/DVD or without
There are Various(different) Methods to Reboot Your Computer 1.) Click "Start," then "Turn Off Computer," then "Restart." else 2.) Press "Ctrl," "Alt" and "Delete" simultaneously. Then click "Shut Down" and select "Restart." 3.) Press and hold the power key. Most systems will power down after about five seconds. This will force a hard power down. This method does not give hardware in the system, such as hard drives, a warning that power will be lost, so it is not graceful and should only be done if the above methods did not work. 4.) Unplug your computer and plug it in. And turn on the computer. This will also make force a hard power down, "Make sure that if the other command/option did not work (function)" so you should only do it if other methods did not work.
Reboot Using a CD or DVD 1.) Place "insert" the CD or DVD into the disc drive of your system (e.g E:,F: or G:) that you have. 2.) Restart your computer using any of the methods listed under "Various Methods to Reboot Your Computer." 3.) When prompted, press any key to boot the computer using the CD. 4.) Contact your computer's manufacturer if this does not work, and make sure that the CD or DVD is good. If not it will not work "Cannot run for booting" or computer may not be set up correctly, and various troubleshooting methods are required to figure out what is not working.
Else if you want to Reboot Your Computer into Safe Mode Here are the step to run in a "safe mode" 1.) Turn off your computer and Wait for few seconds. 2.) Restart your computer. 3.) Start tapping the "F8" key for a while and wait till the "windows advanced option" menu appear. 4.) When the "Windows Advanced Options Menu" appears, select "Safe Mode" using the arrow keys on your computer and press "Enter" key in your keyboard.
All the Best!
Computers & Internet Logo
how do i reboot my hp laptop and it is win XP
If the system is still running and you would like to reboot, click "Start" then "Turn Off" and then select/Click "Restart".
Or you can also press Alt+F4 and then select/click "Restart".
If the system freezes or hangs and you need to reboot, try pressing "Ctrl+Alt+Delete" simultaneously, if this works, then Windows Task Manager will open up, if so, click the "Shutdown" menu and select "Restart".
If this is not the case and your computer doesn't respond to any of the above methods, your only option is to remove the battery and reinstall it back and then turn on the laptop.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 22, 2011 | Computers & Internet
how to reboot my laptop
You question is too short, I have trouble assuming it. Anyway let me try my best to make you understand.
1. If you want to reboot your laptop as soon as it starts up, just press ctrl+Alt+Del on the keyboard, before you see the windows logo start screen. It'll automatically reboot itself.
2. (windows xp), Simplest method is press Alt+F4 and then click Restart f7428f1.png
or if your desktop is set to classic menu, the click on the "shutdown" and select "restart" as shown below;
3. For windows 7, click start, then click the right arrow ">" just right to the "shutdown" button and select "restart"
Or simply press Alt+F4 and select "Restart"
Same steps with the windows vista.
Hope this helps.
Good luck.
thanks for using FixYa.
Jun 27, 2010 | Acer Aspire 5315 Notebook
How do I reboot it? Compaq 5716 runs very slow Can't download anything paid for interent and the computer just freezes. I want to do a system restore where there is nothing on the computer like brand new.
There are different ways on how to reboot a computer. If your laptop is not operational like it's frozen or crashed with the mouse frozen, try the simple steps below:
1. The custom way to reboot your computer is to press and hold the power button until it shuts off. Then press the power again if you want to turn it back on.
2. If your computer is functional and you just want to reboot/restart it, click on Start then click on Turn Off and select Restart. It will restart your computer.
3. If you can't click on the Start button but your mouse is still functional, you can simply press the Ctrl + Alt + Del button on your keyboard to bring up the Task Manager. Then on the Task Manager window, click on Shutdown tab, then choose Restart.
4. If your computer wont turn off no matter what you do, like holding the power button and the steps above, try to unplug the power cable for few minutes then plug it back in. Try to turn on the computer again.
System Restore
Click on START > All Programs > Accessories > System Tools > System Restore
When you do System Restore, this feature will restore your computer's settings back to its normal or functional condition. You can just choose an earlier date where it was working fine. The good thing about system restore is it wont delete your recent saved files and data.
If you really want a clean hard drive/system like what you said (brand new), reformatting the hard drive and reinstalling Windows Operating System is what you need. You need your Windows installation CD to do it. Click on the links below on how to reinstall your Windows Operating System.
5 TIPS BEFORE REINSTALLING OS
How to reinstall OS
Jul 16, 2009 | Compaq Presario 5716 PC Desktop
how do you reboot an acer aspire aoa110-1588
There are different ways on how to reboot a laptop. If your laptop is not operational like it's frozen or crashed with the mouse frozen, try the simple steps below:
1. The custom way to reboot your laptop is to press and hold the power of your laptop until it shuts off. Then press the power again if you want to turn it back on.
2. If your laptop is functional and you just want to reboot/restart it, click on Start then click on Turn Off and select Restart. It will restart your laptop.
4. If your laptop wont turn off no matter what you do, like holding the power button and the steps above, try to remove the battery of your laptop for few minutes and put it back in. Try to turn on the computer again.
These steps are just the basic. If you can tell us more details about your laptop's problem, that is much appreciated. We will provide you exact solution to resolve it.
Have a great day!
Jul 16, 2009 | Acer Aspire 5610-4648 Notebook
118 people viewed this tip
David Payne
David Payne
