Tip & How-To about Cameras
How to Convert MPEG Video to iPad ?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As we all know, iPad is more and more popular in our life. And MPEG is just a common video file, so usually, you need to convert your favorite MPEG videos to your iPad, and then enjoy them on the go! Are you searching for a tool to convert MPEG to iPad?This Video to iPad Converter will be your best choice, which can quickly convert MPEG to iPad.
Now let’s get to know this software together. This powerful Video to iPad Converter is the easiest-to-use video converter software for Apple iPad Movie and iPad Video. It supports MPEG to iPad MP4 format, DVD to iPad (Rip DVD discs, DVD folder and IFO files to iPad video formats), all other popular video to iPad (Convert MOV, WMV, MP4, WMV, WMA, MP3, etc) and even HD video to iPad (Convert MTS, M2TS, MOD, TOD, TRP, TS, TR and more High-Definiton videos to iPad format). What’s more, it supports various iPad video size including H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz.
Now let's go ahead to the way about how to convert MPEG Video to iPad. Following is the step by step tutorial on how to convert MPEG Video to iPad
Step 1: Download and Install Video to iPad Converter
Step 2 : Run the Video to iPad Converter
* Run the program via the desktop icon or the Windows “Start Menu”
* Add MPEG File : You’ll find a simple-to-use interface where you can browse for your MPEG video file by clicking ”Add File” button.
* Output To : Choose your iPad output in the “Profile” pull-down menu. For example: if you have a wifi iPad, select the “iPad MPEG-4 Video (*.mp4)” setting.
* Output Settings : To see/adjust the actual video conversion settings, click on the “Setting” button to open a separate page with all your video settings options: video and audio codec, resolution, format selection and bitrate adjustment. Please note the higher the bitrate is, the clearer the video is, and the larger the output file is. When you’re done, click “OK” to continue.
* Edit MPEG Video (Optional) : This Video to iPad Converter also provides you with simple editing functions. It allows you to trim video, crop play area, adjust video effects like brightness, saturation, contrast. Click the “Effect” button and you can fine-tune the video through dragging the slide bar.
* Start Conversion : Hit “Convert” and go get a snack. The conversion time will depend on several variables including: the duration of the video file, the speed of your computer, the codec you selected and the bitrate you set.
Step 3 : Transfer the Converted Video to Your iPad using iTunes
* Attach your iPad to your computer
* Minimize the MPEG to iPad converter and open your iTunes
* Choose where you want your new movie to go - on your iPad
* And iTunes will sync and put your new movie on your iPad
Step 4 : Play the Converted Video On Your iPad
* Show it to your friends and enjoy!
* “Rinse & Repeat” to convert and transfer more videos to your iPad
OK! Now you have finished conversion. You can enjoy the converted files with the same content of the MPEG Video format on your ipad whenever and wherever you like.
Cameras Logo
How do I convert a file from MPEG to MP3 Format sound
the easiest way to convert mpeg to mp3 sound, is using a video converter to help you.
i know WinAVI All In One Converter support convert MPEG to MP3. this tool is a utility media tool, once you install it, it will help you convert all popular video and audio format, even iPhone, iPod, iPad, X360 box, PSP, most of popular device it support.
Dec 26, 2012 | Audio Players & Recorders
iPad Video Converter - Convert Video to iPad, put Video on iPad
I use Nidesoft Video Converter to convert my video format. http://www.nidesoft.com/video-converter.html
May 06, 2010 | Computers & Internet
176 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
