Tip & How-To about Computers & Internet
Edit MOD on Mac, Cut/crop/merge/edit MOD files on Mac
MOD is a widely used tapeless video format by camcorders such as JVC, Panasonic and Canon in quite some models. And many MOD files come in HD quality. However, when it comes to MOD editing, it can be a headache to a lot users because many video editing software applications do not MOD files, especially on Mac.
Doremisoft Mac MOD Converter does not only work as an excellent Mac MOD file converter, but also works as a great easy MOD editor for Mac.
With this MOD editing software you can cut MOD file length, crop MOD video, merge more than one MOD files into a single file, and edit MOD video effects. The following steps will guide you through how to do the above editing to your MOD files:
Step 1: Add MOD files
Click the "Add File" button to browse your hard drive and import the MOD files you want to edit.
Step 2: Cut MOD file
If you just want the best part from an MOD file, you can cut your MOD video to get rid of the redundant part and only keep the best part you want. Click on the Clip button next to the Add button to open the Cut MOD video window, and follow the methods stated on the below screenshot of the windows to cut your MOD file.
Step 3: Crop MOD video
Click on the Edit button to the right of the Clip button to open the Edit window. Then you will see the Crop window. This function allows you to zoom in a specific area or remove the unnecessary sides from your MOD video. You can just drag the crop frame to specify the area you want to crop. Or you can set the crop values on the lower part of the window.
Step 4: Edit MOD video effects
If you are not satisfied with the video effects of your original MOD video, click on "Effect" tab on the lower left of the Edit window, and you can start to edit the video effects. Here you can set video brightness, contrast and saturation of your MOD video and apply a special effect such as gray, old film or emboss to your MOD video.
Step 5: Merge MOD files
If you want to join multiple MOD files into a single file, you can just click on the Merge button above the Profile list. And after the conversion, the added MOD files will be converted into a single file.
Step 6: Convert HD video
Now, you are done with editing MOD video files, you can just select an output format (eg: if you want to convert MOD to iPhone supported MP4 format) from the Profile list for each added file (if you are not merging them into a single file), and then click on the big Start button on the lower right of the main window to start converting your MOD files into the format you prefer.
Tip: You can tick the "Apply to all" option to apply the same output format to all added files.
http://hdconverterformac.com/article-mod-video/edit-mod-mac.html
If you want to edit your MOD files in a very professional editing software, you can click here to see how to convert MOD files and just convert your MOD files into the formats supported by the editing software you will be using.
Click here to see detailed info of Doremisoft Mac MOD Converter
Computers & Internet Logo
194 people viewed this tip
David Payne
David Payne
