Tip & How-To about Computers & Internet
To Reboot or recovery from CD/DVD problem with OS "Aser"
If you don't press the Alt+F10 key combination or use the recovery CDs, can you get into Windows? Boot with the recovery CDs in. When at the Acer logo during POST, press the F12 key. Then, select boot off CD or DVD. Alternatively, you can enter the BIOS by pressing the F2 key at the Acer logo and go to the Boot tab. There, you can set the CD/DVD drive as the first item in the boot order.
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery. Some manufacturer(s) (e.g. HP) place the recovery files to a hidden (mostly) partition of the hard drive, the others give a Recovery CD/DVD with the laptop.
or
  1. Press the start button from the start menu depending on your operating system(win 2000,xp)
  2. Press Ctrl+Alt+delete combination from the keyboard.
  3. If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds
N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot
or Shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.A few seconds should do unless you have additional problems.
All the Best!
Computers & Internet Logo
I have 2 problems. My Acer Aspire 560z keyboard types garbage for some reason, so I am using an external KB. Then, I want to restore the laptop to factory settings, but the cd's are lost. I don't see a recovery app, and the ALT F10 does nothing... any ideas?
Keyboard - Do you have the NumLock on?
From the ACER support site:
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 12, 2011 | Acer Aspire 5610 Notebook
Acer Aspire One 521 does not boot. When holding down power button - battery charging light goes out and when I hold ear near power connector, I hear clicking noise every 2 seconds. Have tried taking battery and power lead out and holding power button for 30 seconds.
  1. Restart the netbook.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. In order to recover the system using Acer Recovery Media, an external optical disc drive is required.
  2. When the Acer logo appears on the screen, press the F2 key repeatedly.
  3. Press the Left Arrow key until you've selected Boot.
  4. Ensure that the external optical drive is plugged into a USB port.
  5. Refer to on screen instructions to set the first device to USB CDROM.
  6. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  7. Close the CD-ROM tray.
  8. Press the F10 key and then the Enter key to save the changes and restart the netbook.
  9. The computer will boot from the Acer Recovery Media
  10. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  11. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media you may purchase recovery media online. If your computer is unable to run the Acer Recovery process, or errors occur during recovery please contact Acer Support.
Dec 12, 2010 | Acer Aspire One PC Notebook
how do i get a back door password for my acer aspire 5315 as i forgot my password
There is no back door password but you can try this
At the Acer splash screen, you can press Alt and F10 to bring up a DOS style version of eRecovery. The unit is able to reload Windows from this mode faster then from CD. If the hard drive is replaced the system loses its eRecovery features. These features are on the hard drive and cannot be reinstalled
  • Be sure that you back up your data files before performing this option. All of your personal data files and applications are erased during the recovery process.
  • Due to the large number of virus and Spyware threats on the Internet, it is recommended that you disconnect all Internet connections before performing the recovery. After the recovery, antivirus and firewall software can be installed, and then the Internet connection can be re-enabled to update the antivirus definitions and perform Microsoft® Windows Updates.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, press ALT+F10. The easiest method is to hold down the ALT key and repeatedly press the F10 key.
5.Windows loads files. 6. If you get EDIT BOOT OPTIONS for Windows Setup hit the ENTER key 6.1. If you get EDIT BOOT OPTIONS for Windows 7 , Try ALT + F10 (ALT on the right side of the Space bar) 7. You will get the Recovery console , Select completly Restor to Factory Settings.
Dec 08, 2010 | Acer Aspire 5315 Notebook
How to restore accer to factory settings
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.
Nov 04, 2010 | Computers & Internet
Want to Recovery the complete system on my Acer Aspire 0ne 110. How can i do that?
If you have the original "product recovery" CD-ROMs, re-install Windows from those disks.
Otherwise, is there a "recovery partition" on your computer's hard-drive? If so, then you can reinstall from that partition.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Apr 20, 2010 | Acer Aspire One PC Notebook
269 people viewed this tip
David Payne
David Payne
