Tip & How-To about Video Game Consoles & Games
Xbox 360 rrod problem
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
Video Game Consoles & Games Logo
135 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
