Tip & How-To about Computers & Internet
Managing services through registry in windows OS
Its a tip for IT administrators : You can manage your system services through registry values in windows
HKLM > System > CurrentControlSet > Services
Select the service here by short name
Like for USB mass storage select USBSTOR
change Start dword key from 3 to 4 to disable it
Computers & Internet Logo
hi my computer won't recognise my lg hdd.
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
May 01, 2011 | LG Computers & Internet
need security code for wi fi, i.e. wireless key code
Feb 05, 2011 | Computers & Internet
Changed computers and windows vista doesn't want to open our external hard drive
Feb 01, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
I am unable to access to external HDD HXD5 500 GB problem
Dec 26, 2010 | Computers & Internet
how to fix remote connection?
It depends on the problem you are having.
Most often remote connection problems are caused by firewalls
Are you trying to connect across the internet or are your two machines on the same LAN.
Are you only running windows firwall or do you have a third party firewall installed.
I suggest you run off the firewalls first and try to connect on the LAN and then add things back in one at a time until you solve the problem.
There may be more than one thing blocking you.
I hope this helps
Sep 10, 2009 | Microsoft Windows XP Professional
225 people viewed this tip
David Payne
David Payne
