Tip & How-To about Computers & Internet
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP Home)
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP) [IDE]
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39. Or the drive simply does not appear in My Computer or Device Manager.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
Computers & Internet Logo
Can I burn a dvd on my hitachi HL-DT-ST RW/DVD GCC-4241N
According to the information I have to hand, Yes, you can burn CD,DVD's with a good drive.
Hope that answers your question.
You need the drivers for it if you haven't already got them.
Visit Hitachi.com
Jan 02, 2011 | HP Computers & Internet
Will a HL-DT-ST RW/DVD GCC-4241N OC29 burn DVDs
Yes, but you will need a program capable of making dvds also, such as PowerDVD or CDCreator. I use CDBurnerXP (don't worry about the name, it works for all Windows OS's) because it's free.
Dec 14, 2010 | Hitachi (GD-S200) (GDS200) DVD Drive
cd\dvd is corrupted or missing (driver detectiv)
Download microsoft fixit from http://www.ziddu.com/download/6528022/MicrosoftFixit50027.msi.html and install it in your pc ,once its finished jst restart your pc and see it will work
Jan 19, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
HL-DT-ST DVD +-RW GSA-H21N ATA Device is not working gives a code 10....tried for new drivers was all updated..tried to uninstall and reboot then reinstall nada. This is a acer comp.
Right click on “Computer” or “My Computer” in XP. Select Manage and then on the right side select device manager. On the left if you see a yellow exclamation mark next to your drive and were getting any of the above error codes then we have a simple fix.
Go ahead and right click on the CD or DVD drive that has a yellow exclamation mark next to it and select delete or remove.
try to search:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Now that you are at the {4D36E965-E325-11CE-BFC1-08002BE10318} Folder on the right side you will see several entries. right Click and delete the Upperfilters and Lowerfilters. These will be remade once you reboot.
This will try to look for the drivers again..
Jul 12, 2009 | Acer Computers & Internet
HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
497 people viewed this tip
David Payne
David Payne
