Tip & How-To about Cameras
How to import photos to computer
1.If you have mac Operating System You surely need your driver cd came with your camera.
2.Install your driver software to the computer.
3.You want a Usb Data cable for your particular camera .
4.Then connect your camera with the data cable .
5.And another end to the usb port.
6.Now your camera can detected by the computer.
7.Open your camera partition in the computer.
8.Now you can view the photos taken by the camera.
9.Using the copy and paste (cut&paste) or import photos option to import your photos to the computer.
10.This is the way to import the photos from the camera to computer.
Cameras Logo
plugged it in, not working!
Hello!
The situation is a bit confusing as I do not have any details, but let's try solve it together.
Variable webcam models require variable system values and editions.
Please read and follow these steps:
A. First uninstall your camera: Start>Control Panel>Uninstall a Program> find your webcam in the list, click on it and click Uninstall/Change>Confirm/Allow if prompted.Restart your computer.
B. Your webcam's requirements are following:
  • MacOS X 10.4.11 and 10.6.x for iChat and Skype
  • Windows XP(SP2) and Windows Vista for Windows Live Messenger, Skype and Yahoo! Messenger
  • Any desktop or notebook computers with a USB2.0 port available
  • I wish you told me what Operation System you use, as in that case it would be much easier to provide you a good solution.
    • To see which Operating Program you use click on Start, right click Computer and click Properties and you will enter System where all the information about your Operating System s listed. The first line in the first paragraph is the name of your Operating System.
    1. If running Mac:
    As you see in the requirements for installing your webcam you need MacOS X 10.4.11 or more (10.6.x for iChat and Skype), so if you are running less then you need to update.
    Tips on how to update your Mac you can find here:
    http://support.apple.com/kb/HT1338
    2. If running XP:
    Please, make sure your XP is up to date by checking Windows Update (Start>type Windows Update and click enter>click on Check for Updates in the left pane and wait until Windows Update download and install Available updates. You can also check on www.microsoft.com for latest XP updates.
    Note that for now, XP latest update is Service Pack 3: if your Operating System is up to date it should be listed when you open System as I provided above, but still run Windows update just to make sure.
    3. If running Vista:
    Please make sure your Vista is up to date and running Service Pack 2. The info you get in System as I provided above in bold.
    If you do not find Service Pack 2 in your System list (Service Pack 1 or none instead), then please run Windows Update (described in 2.). If you do not get Service Pack 2 automatically, then please visit www.microsoft.com click on Downloads, click on Vista and then double click on Service Pack 2.
    Download it and install, and then restart your computer.
    Check for updates using Windows Update, install any new updates available and restart your computer.
    Now about the USB2 requirement, you need to see your computer specifications as I do not know which computer you use (manufacturer, model).
    C. Install your camera:
    Insert the camera drive CD and if the installation does not start automatically, please do the following: double click on Computer on your desktop>double click on CD/DVD>double click on Driver>Allow/Continue if prompted. If the program prompts you to plug the camera, then you do so and continue installation.
    Restart your computer after the installation is done.
    D. Update camera driver:
    Click Start>right click Computer>click Manage>Device Manager.
    Find your camera in the list, right click on it and click Update. Plug the camera if prompted and continue.
    Restart your computer. Now the device should be working.
    Regards!
    Jun 25, 2011 | Macally IceCam2 Web Cam
    can't install software
    Check this procedure for Software Installation...
    CAUTION:
    Install EasyShare software before connecting the camera to your computer. If not, the software may not charge properly.
    1. Close all software applications that are open on your computer (including the antivirus program).
    2. Place the EasyShare software CD into the CD-ROM.
    3. Install the software:
    Windows: If you install window appears, select Run from the Start menu and type d:\setup.exe, where d is the drive letter that contains the CD.
    Mac: Double-click the CD icon on the desktop and click the Install icon.
    4. Follow the onscreen instructions to install the software.
    NOTE: When the system tells you to take a few minutes to electronically register your camera and software. To register later, visit www.kodak.com / go / register.
    5. When the system is prompted, restart the computer. If you turned off the antivirus software, reopen it. Refer to the antivirus software manual for details.
    For more information, click the Help button in EasyShare software.
    Hope thgis helps.
    Jan 20, 2011 | Kodak Z8612 Digital Camera
    i dont know how to install my camera in computer
    1)FIRST INSERT DRIVER CD INTO CD ROM/DVD
    2)RUN THIS SOFTWARE BY INSTRUCTIONS
    3)CONNECT YOUR CAMERA BY USB/PORT
    4)START USING
    Nov 14, 2010 | Computers & Internet
    how can i use my web cam of oy lenovo g460. is there any software required?
    Hi mbisht19,
    Based on your concern, I suggest trying the following steps:
    1. Make sure that the updated driver has been installed on your computer.
    --> you can download it here:
    --> go to camera section and make sure you download the driver that matches your operating system.
    2. After downloading, install the driver then restart your computer.
    3. Log back in then try pressing the FN+ESC to activate the camera.
    4. Now try to use easy capture to check if the camera is working.
    --> easy capture is a preloaded application in your system.
    --> if you cant find easy capture, you can download it here:
    --> go to software section.
    --> again make sure that you download the application that matches your operating system.
    5. repeat step 2 and 3 then open the easy capture.
    Hope it helps,
    Thank you for using FixYa.
    Sep 29, 2010 | IBM LENOVO VIDEO ADAPTER-G450 32MB 22P6640...
    I CAN'T COPY THE DATA FROM CAM TO PC
    Sep 12, 2010 | Sony Handycam DCR-SR42 Camcorder
    243 people viewed this tip
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
