Tip & How-To about Electrical Supplies
How To Store A Small Engine
Properly storing a small engine is critical for its longevity as well as its readiness the next time that you need it.
For short term storage, about a month or so, storage is easy.
1) Add a fuel stabilizer to the fuel, and run the engine long enough so that the treated fuel is drawn into the carburetor.
2) Change the oil (and filter if equipped) after the engine has cooled a bit, but still very warm. Replace with recommended oil viscosity for current temperatures.
3) It would be a great idea to change the air filter, whether it needs it or not. The next time that you need to use the equipment, you won't have to scramble to find another air filter.
4) Slowly pull the starter rope until you feel the compression stroke, then stop. This closes the valves, and help keeps moist air out of the cylinder.
5) When the engine is cool, tie plastic bags around the air filter housing, as well as around the muffler. This will help keep insects from setting up house inside.
Long term storage, beyond a month, is very different. It is assumed that the equipment isn't going to be used for the rest of or until next season.
1) Mix up a small amount of fuel (quart or so if possible) with a fuel treatment.
2) Empty the fuel tank of whatever remaining fuel is left. Since there will still be a small amount left in the carburetor, now add a bit of treated fuel to the tank. Run the engine until it dies from lack of fuel. A very small amount will remain in the carburetor bowl, but with the treatment, it will be alright. You can remove the bowl to drain, or use a bowl drain if equipped.
3) Change the oil and filter (if equipped) after the engine has cooled, but is still very warm. Use the oil viscosity for temperatures that will be experienced the next time the engine is run. You wouldn't want to put a summer weight of oil into a machine that is going to be used next winter. Change the air filter as well.
4) After oil has been added, disable the ignition (off switch, or remove wire from plug) and pull the rope a few times to get a coating of fresh oil on the inside of the engine.
5) Remove the spark plugs, and pour in a tablespoon or so of fresh engine oil into the cylinder. Not too much though. You just want enough oil in the cylinder to coat the bore while you slowly pull the starter rope to rotate the engine a few times.
6) Replace spark plugs, and pull on the starter rope until you feel the compression cycle, and stop pulling. This closes the valves, and will help keep moisture out of the cylinder.
7) When the engine is cool, tie plastic bags around the air filter housing, and the muffler as well. This will keep insects out.
8) Remove the battery, if it has one, and place it in a location that would be comfortable for you. Don't leave it sitting out in the shed when it is freezing, or do you want it baking in the sun during the summer. Once a month, put the battery onto a small trickle charger to top off its charge, and extend its life.
Removing from storage.
If the engine was prepared for short term storage, then you just need to remove the bags, add fresh fuel (preferably treated), and check the oil. Pull the starter rope slowly through the compression stroke, then start as you normally would.
If the engine has been prepared for long term storage, you will need to obtain replacement spark plugs, but don't change them yet. Remove the bags from the air filter and muffler, reinstall the battery. Check your oil level, and make sure if it is the correct viscosity for the temperatures. Add fresh fuel to the tank, and start the engine.
Because it was stored with oil in the cylinders, it is going to smoke for a few minutes as the oil is burned off. When the engine is good and hot, and the exhaust is clear, turn the engine off. Let it cool down, and change the spark plugs. The plugs that are being pulled out will have carbon deposits on them from the oil being burnt. Use a new set of plugs.
Please consult your user manual before changing the spark plug. Some head castings, particular aluminum alloys, are easily damaged if the metal is warm. Other head castings, such as cast iron and steel alloys, are more immune, but check the manual just to make sure. Besides, you have to find out what gap is appropriate for your engine.
After the plugs are installed, continue to use the engine as you normally would.
A note on stopping the engine on the compression stroke. Many small engines are equipped with automatic compression release mechanism that makes it easier to start. This will make it harder to find the compression stroke, just do the best that you can. Engines with a manual compression release won't have to worry about finding the compression stroke. As long as you don't press the lever, you will know when you come to it.
Electrical Supplies Logo
What type/grade of oil are you supposed to use in Florida for the Karcher gasoline powered 3200PSI
10w-30 will be OK.
I use synthetic oil in all my small engines, but it's not necessary.
Check your oil before each use and drain the gas out and run the carb dry of gasoline before any long term storage.
Getting the gas out of the engine when it's stored will save you having future problems.
Sep 13, 2017 | Karcher Garden
Is working Capital Loan Better For Small Businesses As Compared To Others?
Getting positive working capital is usually critical to keep your small business practical - no matter what sort of business you are running. However some small businesses should be particularly careful to maintain it. Small businesses with cyclical or seasonal sales frequently need more working capital to stay advantageous during their low season. Despite the fact that the small business may additionally make more than enough to pay all its obligations every year, it need to ensure there may be sufficient working capital at any time to fulfill its short-term obligations.
Apr 15, 2016 | Computers & Internet
support skout com
The present study investigates how working memory and fluid intelligence are related in
young children and how these links develop over time. The major aim is to determine which
aspect of the working memory system-short-term storage or cognitive control-drives the
relationship with fluid intelligence. A sample of 119 children was followed from kindergarten
to second grade and completed multiple assessments of working memory, short-term memory,
and fluid intelligence. The data showed that working memory, short-term memory, and fluid
intelligence were highly related but separate constructs in young children. The results further
showed that when the common variance between working memory and short-term memory
was controlled, the residual working memory factor manifested significant links with fluid
intelligence whereas the residual short-term memory factor did not. These findings suggest
that in young children cognitive control mechanisms rather than the storage component of
working memory span tasks are the source of their link with fluid intelligence.
Jun 05, 2013 | Android Apps
kolher magnum 25--worked great last year,now starts right up but runs full throttle...won't idle down ?????????
a stuck float in the carb can cause this as well as old gas do to schlack build up from gas evaperating the carb should be removed and cleaned with carb cleaner and old gaskets replaced a carb kit will run about $20.00 and avail from small engine shops.
the engine number will be needed for the right kit at the bottom of the engine where it mounts there is a flat boss with a number stamped that will be needed for parts.
when the engine is stored the best thing it to run the engine and shut off the gas and run till it stops this will get ride of the gas in the carb there will still be a small amount left in it but follow recommended long term storage prep from the manufacture. hope this helps
May 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
1,869 people viewed this tip
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
