Tip & How-To about Computers & Internet
How to take Care of Your Laptop Battery
BATTERY 101 PART 1
What really makes the Laptop or Notebook really portable is its Battery. Remove the Battery then you are indirectly removing the Laptops portability. As human beings we need energy to survive which is form of the food we eat. Similarly a Laptop needs energy to survive. The energy a Laptop needs to survive comes from the Battery which is made up of chemical juice (Lithium Ions). This chemical juice operates optimally at particular conditions. Hence we need to take care of it. Now if you take away the battery of a Laptop, you are taking away the life of the Laptop. We can then understand that it is the battery of the Laptop that keeps it alive.
Since Battery = Life of Laptop it simply means that No battery = Death of Laptop. Because batteries are so important in the existence of a Laptop we definitely have to take care of our Laptop battery.
HOW TO TAKE CARE OF YOUR LAPTOP BATTERY
I observed that many Laptop owners do not really care for their Laptop batteries. You might wonder why? It is simply Lack of information. So i am going to be giving you several tips on how to take care of your Laptop battery. I am going to cover two tips in this Part of the article and continue in subsequent parts. So watch out for Part 2.
TIPS
1) NEVER ALLOW BATTERY TO DRAIN COMPLETELY
Lithium ion battery is the technology used in modern Laptops. Squeezing every drop of its juice (chemical) weakens and strains the battery. Hence cumulative drain of the battery will shorten the life of the battery and eventually kill the battery.
2) NEVER ALOW THE TEMPERATURE OF THE BATTERY TO BE TOO HIGH OR TOO LOW
High temperature breaks down the battery and reduces its overall life expectancy. Always make sure the vents are unblocked and also never work with a Laptop on the cushion because if you do so you will be blocking the vents in the Laptop. If you are wondering how to check the temperature of your battery you could get a software to do that.
Computers & Internet Logo
ASUS Eee PC Seashell series notebook will power up for a second and then go out
Remove the main battery and try again, have the power supply charger checked to make sure it is working properly, if okay the DC jack in the laptop is a common source of trouble. The unit will need to be taken apart to assess the motherboard.
Jun 03, 2012 | ASUS Eee PC 1015PEMMU17RD 101 LED Netbook...
im stuck on the recovery screen
unplug charger and remove main battery, press power button and hold for 30 seconds and release, let laptop sit for 5 minutes, reseat battery and plug in charger and press power, a long shot.
Mar 06, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
My Toshiba L30 101 wont power up!!
Solution is :-
Please flip the notebook upside down , remove the battery , remove the ac adapter , then press and hold the power button for 30 seconds , then put the battery back , ac adapter back . try to power on the notebook it will work (i believe there is some static stuck in the capacitors of the notebook , which is not allowing it to boot.)
If this will not work in that case :-
You need to reseat the hard drive , and the ram of the notebook .
In order to do so you can refer to this website .
http://www.fonerbooks.com/laptop_2.htm
If the issue still remains its a hardware issue , check the warranty and send it in for repair.
Mar 18, 2010 | Computers & Internet
Dell Latitude D600 won't power on w/ or w/out power adapter
the problem is really mysterious. because in most of cases the battery is the villain. and when it is replaced the issue should be over. there are no other components of a laptop which is directly or indirectly related with battery perfomance.
any way get back me with more details like the age of system and number of times taken to service center etc etc @ deepuunni1985@gmail.com
Aug 22, 2009 | Dell Latitude D600 Notebook
How to disable Laptop battery?
I really never seen such a problem.Your keyboard and mouse doesn't work !!! it only work when you remove the battery of the notebook ??? Do you mean bios battery or a noraml laptop battery ?? Give us more detail.
takecare.
Theknack
Apr 19, 2008 | Acer 3003WLMi Notebook
209 people viewed this tip
David Payne
David Payne
