Tip & How-To about Computers & Internet
Speed up System and avoid problems in Softwares
Just having the Software on O.S. is not enough, you have to do regular maintenance in order to avoid most of the windows xp errors or Software problems and increase the performance.
Steps
(Note: Keep all the programs closed before doing the following operations)
1. Regularly scan your system for viruses using Antivirus
2. Regularly clear all the quarantined files (delete it) (Note: most antivirus creates a directory in C:quarantine empty it.
3. In Windows Explorer, Right click on C: Drive and select "Properties" on the context menu, In the General Tab click on the "Disk Cleanup" Button, in the Disk Cleanup Tab select all the options (no need to worry these are all unwanted files) and press ok.
4. In Windows Explorer, Right click on C: Drive and select "Properties" on the context menu, In the Tools Tab click on the "Defragment Now" Button
select C: Drive by clicking on it and press "Defragment" button (Note: It will take atleast 15Mins to 30Mins depending on the OS Usage. If you are doing on a regular basis then hardly it may take less than 5 Minutes. At the time of defragmentation all programs or scanning should be closes else it does not happen. In between if you like to open programs then just Pause or stop the defrag and run later)
5. Using Add/Remove programs if you have installed any unwanted programs, please uninstall it.
6. Do not have more than one Antivirus program, More than one Firewalls.
7. If any scanner or monitoring softwares of Printer are not used for a long time, then better you uninstall it.
8. In the Start Menu, Click on Run command, type "msconfig" and press ok, select startup button and deselect the unnecessary programs on the list and press Apply button and Press Ok. Restart the system.
8. Store your data files on D: or E: drives or other than the OS installed drive.
9. Do the steps 1 to 4 regularly
10. Once in a year or two if the OS is still slow, reinstall the OS after taking necessary backup and system information on to another drive or partition.(Note: while installing on C:drive or any particular drive do complete format and not quick format.
Computers & Internet Logo
wont start windows xp
Repair Window Xp by inserting windows XP cd in CD drive. After repair use a system utility software like RegInOut to avoid this error in future. It will also fix corrupt registry files and windows files.
Dec 28, 2011 | E-Machines Computers & Internet
have a window7 laptop and cannot download software for futurases2000 so know i hve a embrodiary machine jhat i can't use please help disappionted
Do you have the original disk for the Futura software? Which version of the software do you have? Do you have the 32-bit or the 64-bit version of Windows 7? (To check your version, click Start > Control Panel > System and Security > System. If you see x64 at the end of the OS version, then you have the 64-bit version. Otherwise you have the 32-bit version of Windows 7.)
For the Futura SES-2000 version 3 software:
If you have the original CD, then do you have an optical drive in the laptop? If you do not have an optical drive, you should get an external one (USB connection); these can be gotten for ~$50 or less. (Make sure to have the laptop on AC power when installing software.)
You should be able to start the installation of the Futura software from the CD. For details on the 64-bit install: http://www.futura-support.com/files/Futura%2064bit%20Installation.pdf . In the 64-bit install, you will click OK on several error messages. Then download and install the patch from http://futura-support.com/downloads/updates/Ver3_0_0_9.exe .
For older versions of the software, there are a few options, you could upgrade to version 2.5 or you can maintain a computer with an older version of Windows. (See http://www.futura-support.com/downloads/ce150.html and the Service Updates links in the lower left hand corner.) For the older version of Windows, you can keep a second machine with that OS, a dual boot computer with the OS, or a virtual computer with the older version. If you have Win7 Pro or Ultimate or upgrade to one of them, then you can run a virtual copy of XP for free. Download and install in order: Microsoft's Virtual PC and the XP mode software. Then install your Futura software to the XP computer (as if it were regular OS) and connect the sewing machine and transfer the files for your embroidery. There are other virtual computer programs (Parallels and VMWare). However, XP mode is the only way to avoid needing a licensed version of the older Windows OS.
I hope this helps.
Jul 30, 2011 | Singer CE-200 Quantum Futura Computerized...
issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
microsoft word not responding
try reinstalling the software
Feb 16, 2008 | Computers & Internet
error in windows xp
I would suggest using Spybot Search & Destroy and see if you have any spyware software loaded. Also scan for viruses and use adware to ensure that you are not infected with anything. This should help!
Aug 19, 2007 | Microsoft Windows XP Professional With...
141 people viewed this tip
David Payne
David Payne
