Tip & How-To about Computers & Internet
Changing folder background
Do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
Computers & Internet Logo
how to get rid of windows command processor
How to disable the Windows Command Prompt Note: To follow the steps listed below, you'll need administrator rights and have access to the Microsoft Windows Group Policy editor.
Click Start, and in the Run box type: gpedit.msc and press enter.In the Group Policy window, browse to the User Configuration\Administrative Templates and highlight the System folder.In the System folder, double-click "Prevent access to the command prompt."Change the Setting to Enabled, then click Ok. When entering the command prompt, you should now receive a prompt similar to the example below.
The command prompt has been disabled by your administrator.
Press any key to continue . . .
If you want to re-enable this feature, follow the above steps. However, instead of setting the option to "Enabled", change it to the default setting of "Not configured."
Mar 15, 2015 | HP Computers & Internet
When i tried to to install service pack 2(twice) it downloaded to 24% and stopped . With the error code 8E5E0442 windows update encountered an unknown error .
Perform the following steps to reset the Windows Update component.
1. Stop the Background Intelligent Transfer Service and the Automatic Updates service. To do this, follow these steps:
a. Click Start/All Programs/Accessories. Right click 'Command Prompt' and select 'Run As Administrator'. Click 'Continue' on the UAC prompt.
b. At the command prompt, type the following commands, and then press ENTER after each command:
net stop wuauserv
net stop bits
2. Rename the "Catroot2" folder. To do this, follow these steps:
Type the following commands, and then press Enter after each command.
net stop cryptsvc
ren %systemroot%\System32\Catroot2 oldcatroot2
net start cryptsvc
3. Rename the "SoftwareDistribution" folder:
Type the following command, and then press Enter.
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
4. Register the files that are used by Windows Update and Microsoft Update. To do this, follow these steps:
a. At the command prompt, type the following commands, press ENTER after each command, and then click OK every time that you receive a verification message:
regsvr32 wuapi.dll
regsvr32 wuaueng.dll
regsvr32 wucltux.dll
regsvr32 wups2.dll
regsvr32 wups.dll
regsvr32 wuwebv.dll
5. Start the Background Intelligent Transfer Service, the Automatic Updates service, and the Event Log service. To do this, follow these steps:
a. At the command prompt, type the following commands, and then press ENTER after each command:
net start bits
net start wuauserv
net start Eventlog
exit
Reboot the computer and try Windows Update again. That should get update working gain but your update status may change a bit so you may have to rerun update a few times.
Mar 04, 2011 | Computers & Internet
Hi I have 500gb Roco Hard disk, in which i hide some folder, which i couldnt able view now even after doing "show hidden file option". Thanks
Use the following command in command prompt and your problem will be gone for sure (it will not delete any content) :-
attrib -r -s -h g:\* /s /d
Note:- (replace "g" letter in the above command by your
500gb Roco Hard disk drive letter)
To open command prompt press WindowKey+R and write cmd in the box and press enter. Then write the above command on the command prompt window and press enter.
Some files are also system hidden and they can only be seen using this command.
---->Attrib command is use to change the Attributes of file/folder to showup(unhide) in windows. use attrib/? at command prompt for help.
Hope this will help....cheers:)
Sep 27, 2010 | Office Equipment & Supplies
Surabaya in my birthday
If you are getting message like" Surabaya in my birthday, Don't kill me, I'm just send message from your computer", then it obvious that your computer is infected with Surabaya Virus
Symptoms of Virus
1) All folders get disappear.
2) Folder options not work.
3) Machine Restarts on running command like msconfig , regedit.
4) You are unable to install many antivirus.
5) Folders name appear with scr extension ( Actually not folders)
Reasons of infection
1) Infection from removable drives e.g. pendrive, hard disk,
2) Reading cards using card reader
3) From CD or DVD
4) From others computer
5) From internet
Remedies:
1) Using free software:
Download the "Autorun Eater" from internet ( 1.5mb)
Download from:
http://oldmcdonald.wordpress.com/
http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
a) Install "Autorun eater" ( some Antivirus detect it as a virus but it is safe) and run it. It appears at taskbar ( lower right corner)
b) Right click on it and follow following path
Registry fix>>fix folder option.
(This will repair folder option and it will appear in tool menu)
Now you can see hidden folders
But Surabaya virus change your folder attribute to system folder. So to see your folders you have to untcheck option " hide protected system files and folder" which appears
Right "below the show hidden files and folder" option
Path:
Open my computer>>tools>>folder option>>view>>uncheck show hidden files.. and hide protected system files and folder
How to change folder attributes to normal
You can use command prompt to change the folder attributes
A) Start MS-DOS command prompt (start>>program files>>accessories>>command prompt
B) Type drive letter and attrib command
D:\Attrib *. * -S -H -R /D /S ( Put space between /D and /S switches.)
This will change your all folder option to normal
1)Manual:
a) type "regedit" at command prompt..STRAT>>run>>regedit
b) Search word 'surabaya' in registry...Edit>>find>>Surabaya
c) Delete two entries appeared in search as " LegalNotice Caption and LegalNoticeText"
d) Now using left option tree navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\showfile
check value 0 to 1
Autorun Eater software:
Autorun Eater software helps to protect and remove autorun virus which generally infects from external storage device and internet. This small software is very helpful in conjunction with any antivirus software even it alone can protect your computer from autorun virus(but not complete solution).
(C)infoall , legal: Use above information on your own risk
Mar 21, 2009 | Microsoft Computers & Internet
141 people viewed this tip
David Payne
David Payne
