Tip & How-To about Computers & Internet
Zyxel Prestige 660HW-61 LAN unstability (connecting/disconnecting)
If your LAN is connecting/disconnecting constantly, the problem might be electrolytic capacitor(s) failing in the router. Cap. C162 (220uF/10V) near LAN connectors may be bad and needs replacement.
Computers & Internet Logo
I have the Mitsubishi HD 1080 series when i hit the power button the green LED light comes on and then the power light turns back off what do I do
Hi John
Check the switch mode power supply inside the TV.
Caution.... lethal voltages
The power button is digital these days. That is... it does not have the AC power directly connected to it. Like a normal appliance.
It's a Computer.
Nowadays, the switchmode power supply module converts the incoming AC power to the lower DC voltages required by the other circuit boards.
It uses lots of Electrolytic Capacitors to clean up noise in the DC power. Being Electrolytic they are prone to leaking & bulging so they don't do their job. They won't hold a charge. By pulling the plug and restarting, you have found a way to overcome the problem. But only temporarily. When the Cap goes fully bad, you won't be able to start the TV any more.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 5v to 25V 1000uF or 3300uF.
Replacement Caps can be slightly higher values (not lower) depending on available space.
Also... a higher temperature rating is beneficial.
See Cap Replacement Here
NOTE: Even when Disconnected from the Mains.... Capacitors on the SwitchMode Power Supply board on the 110vac / 240vac Mains Side....can supply a shock hazard to unwary people.
The DC Side is far safer at 5 to 20v
But... There is no Really High 15 to 25Kv inside Digital TV's any more. So... You don't need to leave TV disconnected for a day to discharge these voltages as stated in the attached video.
Samsung TV Power on Problem Capacitor Replacement
How to Repair Your Plasma TV With Blinking LED
How to Replace an Electrolytic Capacitor
Dec 27, 2015 | Mitsubishi Televison & Video
I have a Mitsubishi 1080 Series HDTV big screen not turn the power button TV comes on then TV shuts back off
Hi John
It's a Computer.
The monitor receives power. When I turn it on (connected to my computer of course) it operates for a few seconds and the green LED lights up;however after about 5 seconds the monitor turns off-the green LED then assumes a constant on-off mode.If I disconnect the computer the monitor then displays the small logo indicating that the vga cable is not connected
Any caps in these sections (or any) that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Jun 04, 2011 | Samsung 793S 17" CRT Monitor
Screen flashes protection
If you aren't tech savvy, this unit needs to go in for repair.
IE - it's not a bad idea to replace a 10V cap with a 16V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Mar 01, 2011 | Televison & Video
476 people viewed this tip
David Payne
David Payne
