Tip & How-To about Computers & Internet
Remember the position of screws tip from www.alllaptoprepair.com
Make a xerox copy of the area. Foe example: if you want to take out screws from the bottom of the laptop. Make a copy of the bottom of the laptop. After removing the screw, place the screw at the same location on the print copy. You can visit us at www.alllaptoprepair.com and request a free DIY Lapptop Troubleshooting and Repair Guide.
Computers & Internet Logo
We have a Xerox copier 5818 and it has an error code of U7 which indicates to contact a service technician. Not finding one in our area. Do you know what this code indicates and can we fix it ourselves?
Normally changing the copy cartridge will resolve it.
There is also a belt hole sensor mounted on the front of the machine, It is located on the upper frame about half way back.
You can identify it this way. It has 2 screws in it and has 2 heavy red high voltage wires running out of it.
The screws sometimes strip and it is out of position, or the window on it is dirty.
But I would assume the copy cartridge needs replaced
Jan 07, 2010 | Xerox Office Equipment & Supplies
Area where final copies come out of machine making
Sounds like the output clutch. Take the top off the fuser area and clean the clutch.
Dec 04, 2009 | Xerox WorkCentre 432 ST Copier
xerox m20i scanning problems
its probably set to a low DPI.......change your dpi to like 600 when scanning
Nov 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
When photocopying, a copy is made however the text also appears faintly in the background. (Model no: Xerox WorkCentre XD120F)
That would be either a bad heat roll or pressure roll.
In the area where the copy exits, the hot fuser area, eithet the heat roller, TOP roll or pressure roller, Bottom red roller are worn.
Easiest thing would be to replace the fuser.
Contact this parts reseller.
https://www.partsdrop.com/store/
Apr 21, 2008 | Office Equipment & Supplies
101 people viewed this tip
David Payne
David Payne
