Tip & How-To about Computers & Internet
Anu Script Manager 6.0
ANU 6.0 does not work properly in some computers depending on the configuration, like showing an error message "Error: error locking driver" etc. In such situations, instead of uninstalling and reinstalling the application everytime, open "Anu SM" folder in C: drive, there you will find a file "postins2". Double-click it, it instals the fonts again. Now click the Anu icon on the desktop, it asks you whether to restart computer. Reboot the system and start working with ANU 6.0!
Computers & Internet Logo
canon pixma 922 won.t print..computer says not printer not responding also says printer in error state..no printer codes showing
Depends on if you have it set up correctly for proper port config. Is it set up for USB or LPT? Check it out with PRINTERS showing printer details on driver etc.
Feb 23, 2015 | Canon PIXMA Office Equipment & Supplies
I have windows xp an error message box pops up that says at the top message from webpage [object error] it wont go away after xing it hitting ok or alt control delete. Everthing is locked up depending on that box to be gone.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer this may vary depending on your computer and operating system If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details or You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps. Hope it helps.
Jan 05, 2013 | Computers & Internet
what is lock protection error for anu script manager
what is lock protection error for anu script manager i have installed anuscrip 6.5 and after instalation i got lock error
Feb 21, 2011 | Adobe PageMaker 7.0 Classroom in a Book...
pls help - my sound card driver is not working properly when i ply files on winmap show a error massege- baddirect sound driver. please instal proper drivers or select another device in configuration. error code : 88780078
You can try going into your sound driver and selecting properties. Try rolling back driver. If that doesn't work, go to device manager, select sound card, uninstall device, reboot computer and let windows reinstall the device. At that point windows should load its latest driver.
May 26, 2010 | Office Equipment & Supplies
M2N-MX sound
Try reinstalling the drivers, which can be found here.
Apr 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
336 people viewed this tip
David Payne
David Payne
