Tip & How-To about Intuit QuickBooks: Premier Manufacturing & Whosale Edition 2005 (284224) for PC
Solving printing problems in QuickBooks
If you are having problems printing in QuickBooks, follow these simple instructions to set up your printer correctly.
Open QuickBooks
Go to "File" at the top left side of your screen & click on it
This will open a drop down list
Choose "set up printer" & click on it
This will take you to a list of forms printed in QuickBooks
Choose the form you want to print & click on it
This will take you to a place to choose & set your default printer
Find the box that has the current default printer in it & look for the arrow
Click on the arrow next to the box with the printer name
This will give you a drop down list of printers to choose from
Find the name of your printer on that list and click on it
Then save your choices by hitting "ok" and closing the box
Repeat these instructions for each form you wish to print in QuickBooks.
Intuit QuickBooks: Premier Manufacturing & Whosale Edition 2005 (284224) for PC Logo
printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have XP and QuickBooks Pro 2007. QuickBooks PDF Converter shows up with my printers, but when I am in QuickBooks, and click on print, it is not an option. I have removed and re-installed the converter several times, re-started, etc...it still doesn't show up as an option. When I use the option in File, it tells me I can't print to that file.
You want to print things while in QuickBooks right? That's your problem? If so, then open your QuickBooks file and go to "file" at the top left of the screen. Click on File and then choose "set up printer" from the drop down list of choices. This will open up a list of forms. Choose the form that you wish to be able to print. Then lick on the arrow next to the printers name that comes up as the default chosen in QuickBooks. Change the printer name to the printer that you want to use to print the form. Then choose "ok" and close the window. Repeat the same instructions for each form that you wish to print with your printer. You dont want to use the QuickBooks PDF converter as the choice of printer. It's not a printer driver.
Nov 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks Pro 2007 Printing Blank Invoices
Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'.
Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected.
If the above are set correctly, go to HP's website and download the latest driver for your printer.
Jul 13, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Hp6500 won't print my invoices from Quickbooks, Help!
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
Jun 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My printer will not print.
When you get to the "Print" window, there should be the area where it says the type of printer. There is also a drop-down arrow. Click on the arrow and highlight your HP printer.
Jan 27, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
985 people viewed this tip
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
