Tip & How-To about Radio Communications
How to tune your SWR on your CB Radio.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Radio Communications Logo
I need to know how to tune my cb radio. I have a Cobra 19DXIV and I can only hear certain people and they have to be within 50 feet. I also need to be able to hear the people close to me and people that are a block or two away. Is there anything I can do without tuning the antenna. Thanks for your help.
1. Turn to CH 1
4. Turn to CH 40.
Nov 15, 2010 | Cobra 19 DX IV CB Radio
I hooked up my radio and when i push the mic the red antenna light came on so i grounded the radio better still did it changed the braket for the antenna still same thing changed antenna still samr thing running out of things to do what is the problem?
1. Turn to CH 1
4. Turn to CH 40.
Nov 10, 2010 | Uniden GRANTLT 40-Channels Base CB Radio
I lost my manual and I don't know how to calibrate my CB its a cobra 29Ltd chrome edition
1. Turn to CH 1
4. Turn to CH 40.
Oct 21, 2010 | Cobra 29 LTD CB Radio
i have a cobra 150 gtl dx cb radio. my reception and transmition is not at peek performance. can you help me please? i have tried everything i know to do.
If this radio has been peaked and tuned already, and it is not in need of a full alignment, then it's most likely the antenna.
Your antenna is everything. You need a good antenna, and it needs to be tuned to the lowest SWR.
1. Turn to CH 1
4. Turn to CH 40.
Oct 20, 2010 | Cobra 150 GTL DX Base CB Radio
WHEN I TAKL HAVE DISTORTION MY COBRA IS CB COBRA 19 ULTRA 111 BUY NEW. SOME PEOPLE SAY YOUI ARE OUT OF FQ.
your not out of frequency. Your antenna is not tuned.
  1. Turn to CH 1
  4. Turn to CH 40.
Jun 21, 2010 | Cobra Radio Communications
402 people viewed this tip
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
