Tip & How-To about Cameras
Canon Digital Rebel autofocus problem (EOS 300 and 350)
Hi.
A number of complaints from Digital Rebel EOS owners reported that the auto focus feature suddenly stopped working. In some case the picture was showing a dark shadow on the lower side.
The problem is a factory defect caused by a factory defective autofocus sub mirror. The problem is known to most repairers ( and sadly to users ). Although the defect due to design problem, Canon never acknowledge that this is a factory defect, and never issued a recall and free repair notice for Digital Rebel defective autofocus.
THe repair is done replacing the mirror. The cost ranges between $120 and $180.
As first line of action, check any of the links below, and call Canon. Complain, and see if you can get discounted repair.
If that does not work, the alternatives are using the camera with no AF, or having the camera repaired at own expenses. Often the sub mirror may get even more stuck, and pictures start showing the black shadow from mirror on lower part of the picture.
This is the cause of your troubles:
Here one of several repair websites dealing with the problem. I quote:
"Most autofocus repairs are related to problems with the small mirror under the main mirror (known as the sub-mirror). There is a plastic post that operated this mirror which sometimes breaks. We replace this post with a brass pin so that the problem will not recur. "
Here one of the many forums on the problem. Please read the testimonial from other users, it is quite instructive.
Other forum.
Here replacement pin.
Here how to do the repair.
Here Canon contact:Canon technical support phone number.
Good luck.
Cameras Logo
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Mar 24, 2012 | Canon Digital Rebel EOS 450D EOS Rebel XSi...
auto focus blocked Canon Eos 1000D
when i get on auto focusthe camera doesnot work
May 13, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
610 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
