Tip & How-To about Computers & Internet
How to Create and Remove SQL Server Password
SQL Server is a Microsoft product used to manage and storeinformation. It uses tables to contain large sets of records for thedatabase. Do you have a SQL server and have you ever used SQL server?Do you know how to create a SQL Server passwordto protect your data stored on SQL server? What to do if you forgetyour SQL password? Following it will introduce you how to create a SQLpassword. And it also tells you how to remove SQL Server password ifyou forget as password can be easily lost.
How to create a SQL Server password?
As we know, it is an important security measure to set a passwordfor user accounts and in particular the SA account. And it is very easyfor you to create a SQL Server password. Just follow the simpleinstructions.
1. Open the Microsoft SQL Server Management Studio program from the Start menu bar in Windows.
2. Click on the SQL Server instance on which the new user will be created.
3. Right-click the Security folder, point to New, and then click Login.
4. On the General page, enter a name for the new login in the Login name box.
5. Select SQL Server Authentication and enter a password for the login.
6. Select the password policy options that should be applied to the new login. In general, enforcing password policy is the more secure option.
7. Click the OK to complete the creation of the new user.
Sometimes it happens that you ignore or forget the systemadministrator password. What will you do if you forget SQL password andcannot access to SQL database? The effective way I know is to remove SQL Server passwordwith the help of SQL Server password remover software. MS SQL ServerPassword Unlocker is one of the good MS SQL password remover toolswhich can help you remove SQL password in a few seconds.
How to remove SQL password with Windows Password Unlocker?
MS SQL Server Password Unlocker is handy SQL Server password remover software for you to reset SQLpassword including reset SA password and other user passwords. It caneasily remove SQL Server password for Microsoft SQL Server2000/2005/2008 in a minute. You don’t need to install MS SQL Server onyour PC, and the file in master.mdf format is enough for you to removeSQL Server password and set a new one for it.
Step 1. Download and install MS SQL Server Password Unlocker, and run the application.
Step 2. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with the newly set SQL password. Although it is easy for you to remove SQL Server passwordwith SQL password remover, it is better to keep your SQL password inheart. Or you can also write it down on a paper and keep in a safeplace.
Computers & Internet Logo
Is it good idea to repair sql file?
Bulk Logged will not help you in this situation. Your transaction log is growing because you are performing large transactions. In simple mode, the log is truncated after a checkpoint.
Check these site: http://www.sql.recoverytoolbox.com/ & download demo Recovery Toolbox for SQL Server.
Depending on how you are loading your data, you may need to break it up into smaller chunks. Make sure you are not loading all the data in one large transaction.
Read more: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/380-is-it-good-idea-to-change-simple-recover-model-into-bulk-logged-on-etl-system
Nov 06, 2014 | Microsoft SQL Server 2005 Standard Edition
restoring files from the database
I suggest you use the Enterprise manager (gui tool to manage SQL).
Restoring a single table is not an option.
You can however restore a file or filegroup.
Make sure to backup before you start and NOT to restore database to its original name or original file location, to avoid acidents.
Normally you will have databases with only 2 files: the data at its Primary file group, and log file.
You may wish to create a new file group and move tables to the new group by recreating them there and exporting data from old table to new table. Then recreate indexes. This may prove to be complex as all tables and indexes have unique names and can't coexist with exact duplicate of them.
oh yea..... did I say backup?
well just in case backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup
but dont overwrite that backup
Feb 11, 2008 | Microsoft SQL Server 2000 Standard Edition...
help me....
You have to creat a table in the SQL server db then you can
a) use some windows host script or vb to read your data and insert into the db..
b)you can also use the acess:
Oct 13, 2007 | Microsoft SQL Server Standard Edition for...
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
182 people viewed this tip
David Payne
David Payne
