Tip & How-To about Computers & Internet
How to convert video for beginner
In this article, i will provide four useful tips about how to make successful video conversion. For those who don't have a lot of time to learn the intricacies of video conversion, but want an easy way to produce good looking video, this article may well suit you.
Tip 1 – Understand Some Basic Knowledge.
A thick tedious book full of abstruse scientific terms is needed to know what each video format means and the details how various video formats are created. But we don’t have to be a scientist in order to make a video conversion, some basic knowledge is enough.
Most video files have at least two different types: the container, and the codec.
A container is a computer file format that can contain various types of data, compressed in a manner of standardized codecs. The container describes the structure of the file: where the various pieces are stored, how they are interleaved, and which codecs are used by which pieces. It may also specify an audio codec as well as video.
Codec, short for compressor/decompressor, allows you to store the digital music, photos, and movies in the form of compact, manageable files, which can then be opened or decompressed to deliver the original contents. The common video codecs include DivX, XviD, 3ivx, MPEG(MPEG-1,2,3,4), ReadVideo.
A video can be thought of as being made up of numerous snapshots, called frames. Frame rate is the number of still pictures per unit of time of video, and most often expressed in frames per second (fps). Motion pictures shot on film do so at 24 FPS. Both video and audio file resolution is measured in kilobytes per second (kbps) — that is, how many thousands of bytes it takes to store one second of sound or videos. This figure is known as the bitrate. A higher bitrate allows better video quality.
Aspect ratio describes the dimensions of video screens and video picture elements. All popular video formats are rectilinear, and so can be described by a ratio between width and height. The screen aspect ratio of a traditional television screen is 4:3, or about 1.33:1. High definition televisions use an aspect ratio of 16:9, or about 1.78:1. The aspect ratio of a full 35 mm film frame with soundtrack (also known as the Academy ratio) is 1.375:1.
Video is made up of static pictures being flashed before us in rapid succession. When we talk about picture resolution we are referring to the elements, pixels, which make up the pictures. For example, iPod classic video is 320*240.
Finally, theoretically video conversion won’t improve video quality. You shall not expect better quality than source video.
Tip 2 - Find and Buy One Good Video Converter.
A good video converter is vital to whether you can successfully finish video conversion.
There are tons of available video converter applications on the internet. Best video converter can make you look like a video whiz with minimal effort. Since most video converters are trialware, you can try before purchasing.
We summarize four criteria when evaluating video converter software:
Input Files- It should accept a wide variety of input files especially your source video formats.
Output Files- You may only need to output to a handful of formats, whereas the number and breadth of output files typically determines the strength of the converter’s overall performance.
Features- The features includes the ability to adjust multiple options including video size, codecs, bitrates and frame rates, to ensure high quality. You may think those features are reserved for advanced users, not to a video rookie, but as we introduce below, a broad feature set which is readily available and easy to find is also important to your conversion success.
Ease of Use- The software interface should be intuitive and non-threatening to the novice user. Most video conversion tasks should be done in several clicks.
With a good video converter, you are close to success.
Tip 3 – Make Appropriate Setting.
A lot of the ugly-looking grainy clips you see online are the victims of bad conversion practices. Poorly encoded or converted video can end up looking horrible, which is an eye torture.
To avoid this, you need to make sure you take the correct output settings. Some video converters have provided some convenient way to optimize the output. In AVS Video Converter, there are various preset optimized profiles which can be used to fit diverse multimedia devices.
Those preloaded profiles cover most our requirements. But you can still modify some parameters according to your specialized requirements. As introduced in Tip 1, you can customize the frame rate, bitrate, video size, aspect ratio, etc., to get best result. For example, you can increase the value of video/audio bitrate to get a higher image/sound quality and for a compressed file you can decrease the value. You can save the customized profile for handier usage and quicker access in the future.
Tip 4 – Editing Video in Your Way.
Stop thinking video editing requires professional expertise and only Hollywood geek could do it. Most video converters allow you to add a wide variety of eye–popping effects to your videos. You can clip, crop, apply visual effects, and add background music, subtitle and watermark to personalize your movies, transform it into a work of art. Good video converter tool usually provides detailed help information which is easy to understand. Feel free to try out the available editing functions then you will master them.
Computers & Internet Logo
Can anyone give me any tips for learning to use a bodyboard?
Livestrong has a really good article with some basic tips for learning to use a body board. Good Luck - it looks hard but a lot of fun.
http://www.livestrong.com/article/472791-bodyboard-like-pro/
Feb 28, 2013 | Toys
How to Rip and Convert 2D DVD to MP4 3D Video You really love the great effect that 3D videos bring to you, but don't have enough 3D resources? Then create 3D yourself! Use DVDFab 2D to 3D Converter, you can convert a 2D DVD to 3D videos for playback on PC with specific player software such as NVIDIA 3D Vision Video Player or Stereoscopic Player, or you can view them on a compatible 3D TV. In this tip, you'll learn how to convert DVD to MP4 video with 3D effect, just read on. Required tool: 2D DVD to 3D Converter Rip 2D DVD to MP4 3D Video>Step 1: Fire up 2D to 3D Converter DVDFab 2D to 3D Converter is embedded in DVD Ripper, Blu-ray Ripper and Video Converter for different tasks as a "2D to 3D" option. For this task, we need to use DVD Ripper. Just run DVD Ripper, choose "to MP4" mode. Then import in the source DVD, and check the "2D to 3D" box to enable 2D to 3D Converter. Rip 2D DVD to MP4 3D Video>Step 2: Set up for conversion Now let's set things for conversion. At first you need to choose one or more titles for conversion (longest movie title is always selected in default), and choose your favorite audio tracks and subtitles, and if your want to choose only a segment of a title for conversion, you can select the title's start and/or end chapter to specify the segment via "Title Start/End Settings" button. One neat thing is that you can preview movie title in real time to check previous settings. Now let's go further to click "Video Effect Settings" button to set for the output 3D video effect in the following windows, you can see all things in detail from there. Click "Edit" button to pop up below window. You can set lots of parameters for video, audio, etc. Rip 2D DVD to MP4 3D Video>Step 3: Start conversion Alright, now hit "Start" button on the main interface to trigger conversion process. When everything is being converted, you can view detailed progress status with data and pictures, and you can choose to go away to relax by setting auto shutdown for your computer, then return to collect your output MP4 3D video. OK. The process will be completed quickly, and you'll successfully create your own 3D MP4 videos out of a normal 2D DVD. It's fantastic. Enjoy yourself.
Jul 05, 2011 | Computers & Internet
197 people viewed this tip
David Payne
David Payne
