Tip & How-To about Garden
How do I keep squirrels from eating my sunflowers?
Give the squirrels another source of feed/seeds.
1.Give the squirrels their own feed away from the location to which you will be growing the sunflowers.
2.Do this before growing the sunflowers. This will get the squirrels in a pattern and to a location away from your sunflowers.
3.Keep the squirrel food container (s) full at all times. If thesquirrels are full they will not have reason to eat the sunflower seeds.
Squirrels would rather eat peanuts, seeds, oats, breads, and/or what ever you want to give them over your sunflower seeds.
** To get the old squirrels away from a location they occupy now, is to train them away from it.**
Gradually move their food source away from any location they go to now.
Once you have them following the food, keep moving it until the foodsourced is in a location you would prefer the squirrels to go to forfood, rather than the squirrels eating your sunflowers....
Good Luck!
Hunnybunny11
Garden Logo
growing indoor avocado tree from seed
Make sure it doesn't stand in water, don't give it too much. Moist is OK, but it needs to all drain out. Also, don't let soil cover the top of the seed area. Mulch on top is OK, but not right over the base.
Jun 27, 2017 | Garden
How do I repair a dead patch of grass ?
Rake it clean of thatch.
if you can see dirt, add seed
if you cannot see dirt, stab the area with a spade every 1 to 2 inches. then add seed. just a disperse layer of seed (not a full solid covering of seed)
cover with 1/8 inch of top soil, manure mulch/mushroom mulch or chopped straw
water
let grow (water 2x per day - enough to wet the seeds)
mow ow the first time when more than 4" tall
Aug 05, 2014 | Garden
How need in the soil should I plant parsley seeds?
Parsley seeds should be planted shallowly, under a light bed of moist soil. I put mine down only about 1/4 of an inch. They will start sprouting within about a week.
Aug 05, 2013 | Garden
How far apart should i plant bean seeds?
Bean seeds should be planted at least three inches apart. They grow quickly and their leaves are wide so you want to give them room to grow.
how to propagate a calamansi seeds?
There should be no particular problem. Just sow them about 1 inch (25mm) deep in small pots of seed compost. Germination will take 14-21 days at 75F (24C). Transfer to larger containers of freely-draining soil as they grow.
Sep 29, 2009 | Garden
569 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
