Tip & How-To about iPhone Apps
PocketGuitar
All of you who experience 'no sound'... realize that the bottom space below the fret board is where you strum... then you get sound.
iPhone Apps Logo
Why is there a faint crackle from the amp when I strum?
Assuming that the problem goes away when you plug a differebt guitart into your amp, you have a loose ground somewhere in the guitar.
Aug 09, 2015 | Music
There is a noticeable ringing sound only when I strum any note on the E string , any other string sounds fine.
If the ringing only occurs with a specific range of notes it may be something rattling in the amp loose or speaker enclosure.
It could also be feedback occurring at certain frequencies - does the ringing stop if you turn the volume down a bit or stand in a different position in relation to the amp?
Could be a problem with your guitar? Maybe the pick up height needs adjusting in relation to the E string or is it the string buzzing against a fret - indicating a need for adjusting the bridge height or trussrod settings?
Feb 27, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
If I strum harder on my guitar a buzzing noise comes out of the amp. Also every sound I try on the amp sounds very twangy and painful to the ears. I use an overdrive pedal with it, but every setting is just very twangy. I dont know if it is the amps problem but it is very frustrating because I can never get the sound I want.
If you don't want distortion, get rid of the overdrive pedal... Twangy USUALLY comes from the GUITAR and NOT the amp... test it on a different amp to decide... Buzzing CAN be caused by "fret buzz" which is due to IMPROPER guitar setup such as neck bend and string height.
Start using ONLY clean channel on the amp and NO reverb. If you verify that the guitar sounds bad on a different amp, take it in to have it setup properly.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
guitar strums by itself, tilt star power is not sensitive enough
Please read my solution here - http://www.fixya.com/support/t1465253-miss_firing
Jan 05, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
908 people viewed this tip
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
