Tip & How-To about iPhone Apps
Warship: Flight Deck Jam
That's a cool game! Every equipment in the game is located on a block of space and can only move horizontally OR vertically
Read more: http://iphoneapplicationlist.com/2010/07/16/warship-flight-deck-jam/#ixzz0xijAktvj
iPhone Apps Logo
Are the filters for my Ruud 80 plus furnace supposed to be installed vertically or horizontally?
Hello Donna Haslam
What ever EFECTIVELY BLOCKS all air
BEFORE it enters your heater...
Check out your air intake...
If this is the DESIGN EXERCISE it feels like...
Consider buying an INTAKE HOUSING
that takes a STANARD SIZE air filter.
FILTER...
AT THE INTAKE is a superior location
because it prevent dust & "stuff" from
EVER ENTERING your DUCT work.
Carnac
Carnac the Magnificent
Mar 19, 2017 | Ruud Heating & Cooling
HOW CAN I MAKE HALF SPACE?
A half vertical space is made With the paper up or down keys.
The horizontal space Code backspace will move you back in small steps.
DickyO
Sep 03, 2010 | Lexmark Wheelwriter 1000 Typewriter
what is best position for console horizontal or vertical
I keep my xbox 360 horizontal because my disks get less scratched this way and no fans are blocked.but if you keep it this way, DO NOT put a graphic on the 360
Hope This Helped =)
Dec 27, 2009 | Microsoft Xbox 360 Console
Eye Cleaning
Step One: Purchase the Wii Lens Cleaner directly from NINTENDO. This can be done online at nintendo.com. Contact their support team if you are experiencing disc read errors, as you may be eligible for a free Lens Cleaner.
Step Two: Plug the Wii into an outlet and eject any game that might be in the system.
Step Three: Release no more than three drops of the liquid onto the cleaning pad. Too much cleaning fluid could be harmful to the system's internal components.
Step Four: Place the lens cleaner into the Wii's disc slot. Make sure that the system is powered on and that the blue lines on the cleaner are vertical. The Lens Cleaner should be inserted with the top facing the right side of the system when vertical, and the top when the system is laid horizontally.
Step Five: Move the Lens Cleaner gently up and down in vertically-oriented systems and left to right in horizontally-oriented systems. Move it 3/4 of an inch between 10 and twenty times.
Step Six: Press "Eject" to remove the Lens Cleaner. You should not need to use any force to remove it
Dec 22, 2009 | Nintendo Wii Console
693 people viewed this tip
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
