Tip & How-To about iPhone Apps
'The Moron Test' application
'The Moron Test'. You'll kick yourself when you fail to follow these simple instructions! Master the test, then share it with your friends! The Moron Test - the one and only "reverse-IQ" test! And here goes the tip: There are hidden sounds throughout the game. Try to find them
iPhone Apps Logo
water service test
Good Afternoon Friend,
I understand you want to know how to run a water service test on your Frigidaire dishwasher. Typically, this is not a do it yourself test, as there are no step by step instructions. I suggest either contacting the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire Dishwashers
HOW TO SHARE FILES AND PRINTERS BETWEN WINDOWS 7 AND VISTA With three different versions of Windows being used now, you?ll probably find yourself trying to share files or printers between them. Today we take a look at how to share files and printers between Vista and Windows 7 machines. In this example we are on a basic home network using Windows 7 Ultimate (64-bit version) and Windows Vista Home Premium SP2 (32-bit version). Set Windows 7 Share Settings On the Windows 7 machine we need to set up a few things in Advanced Sharing Settings. First type network and sharing center into the search box in the Start Menu and hit Enter. Then click on Change advanced sharing settings? Now in Advanced Sharing Settings, make sure to turn on network discovery, file and printer sharing, and public folder sharing. Make sure these are enabled in both the Home or work and Public profiles. Depending on your setup, you might want to turn off password protected sharing. Other wise you?ll need to enter the password for each machine in, which isn?t that big of a deal. Turning it off while you?re setting it up makes things a bit easier though by saving a step. Set Vista Share Settings On the Vista machine we need to double check and make sure it?s sharing settings are ready to go. Right-click on Network and choose Properties. The Network and Sharing Center opens up. Under Sharing and Discovery we need to turn on File Sharing, Public Folder Sharing, and Network Discovery. Also on the Vista machine you might want to turn off password protected sharing ? but it?s completely up to you. Share Files Windows 7 View Now that we have the correct Settings On each machine, it?s time to put it to the test. Open up Network on the Windows 7 machine, and you should see all of the machines on the network. The Vista machine in this example is VISTAGEEK-PC. There was no need to enter a password to access the Vista machine because password protection is turned off. But now you can go through and see the User Shared folders. In this example both public and Users directories are shared. Share Files Vista View Now on the Vista computer, double click on Network and you should see the Windows 7 machine (where in this instance it?s MYSTICGEEK-PC). I enabled password protection on the Windows 7 machine so we can take a look at the login screen that will be displayed before connecting. Then you?ll see the folders and devices that are shared. Here you can see the HP printer connected to the Windows 7 machine is available. And you can continue browsing through all available shared folders and files. Printer Sharing As we showed above, you can see the printer connected to Windows 7. Let?s make sure we can connect to it and print a test document. In Vista click on the Start menu and type printers into the search box and hit Enter. Right-click on the shared printer and select Properties. Under the General tab click on the Print Test Page button. The following message is displayed while the test page prints out on the printer connected to your Windows 7 machine. Another test you might want to perform is opening a test document and making sure you can print that to the Windows 7 printer. Provided everything prints out successfully you might want to make it the default printer. Troubleshooting If your machines aren?t able to see each other or the printer isn?t working?here are a few steps you might want to use to determine where the problem is. Double check to make sure Network Discovery and File and Print Sharing is enabled on both machines as shown above. In this example both machines are connected to a Belkin home wireless router and IP addresses are dynamically assigned. If you are using Static addresses make sure you can ping the IP address of each computer. If not, double check the assigned IP Address and cabling of each computer? If the printer isn?t working, double check to make sure you have the latest drivers for each OS installed.
May 24, 2010 | Computers & Internet
instalation of ad on IDE/SATA PCI card
You have to set one of the DVD as Master end the other as Slave if they share the same ribbon connector. Do this simple test: let only one of the DVD connected. If the PC "sees" this one, then the card is OK. If need more instructions, just post a comment.
Apr 16, 2009 | Computers & Internet
578 people viewed this tip
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
