Tip & How-To about iPhone Apps
Bookmark app tip for Iphone
Bookmark starts playing whatever you were last listening to. You don't have to search for a book or even press play.
iPhone Apps Logo
Can you add a bookmark?
How to use the GoGear bookmark feature in Audio books:
Adding a bookmark
  • During play, press "Option" button.
  • Select "Bookmark".
  • Select "Add bookmark".
  • Press "Play" button to save bookmark.
Accessing a Bookmark
  • Select "Go to bookmark".
  • Select bookmark from the list you want.
  • Press "Play" button to play the selected bookmark.
Removing a Bookmark
  • Select "Delete bookmark".
  • Press "Play" button to delete the selected bookmark.
Oct 10, 2013 | Philips Gogear SA2RGA04KS Mp3 Video Player
I can figure out how to set a bookmark but I can't figure out how to select one to play. Help please. Thanks
A bookmark marks a point within a track, so you can return to it at a later time.
For example, if you are listening to your recording of an interview, insert a bookmark if you need to stop halfway through. When you want to continue listening from where you left off, go to this bookmark.
You can use up to 10 bookmarks at any one time.
To insert a bookmark
  1. Play the track that you want to bookmark.
  2. In the Now Playing view, while the track is playing, press options.jpg and select Set Bookmark.
  3. Select a bookmark number.
    If all 10 bookmark numbers have been assigned, clear an existing bookmark. In the main menu, select Music > Bookmarks. Press options.jpg and select Clear Bookmark.
To go to a bookmark
  1. On the main menu, select Music > Bookmarks.
  2. Select the bookmark that you want.
Oct 09, 2009 | Creative Labs Creative Technology Zen MP3...
Recording favourite tracks
After bookmarking the selected tracks and you are ready to copy them to the HDD, make sure the bookmark abbreviation is lit up in the display. All you have to do is press the bookmark button on the remote or on the recorder- after pressing "copy" but before pressing play.
May 15, 2008 | Yamaha CDR-HD1300 CD Recorder
No longer holds a bookmark
I've had my MuVo V100 for a year and can tell you it only saves the bookmark for the last file played. Hence, if you're into a long audiobook, don't switch to another. I've taken to making note of where I am because if the battery dies while playing it will also go back to the last saved bookmark.
TIP: if you accidentally switch away from a book you're listening to, pull the battery BEFORE turning it off -- it will revert to your last bookmark.
my 2 cents
Jan 20, 2008 | Creative Labs Muvo V100 MP3 Player
660 people viewed this tip
Top Apps Experts
Lesley Cameron
Lesley Cameron
Are you an App Expert? Answer questions, earn points and help others
