Tip & How-To about Televison & Video
CHECK FAN NUMBER 2 (SAMSUNG DLP TV)
If you ever had the fan problem then you know they sell these fans at quite a high price, some sell for $50. A suitable replacement can be found at your local computer store and online. The specs on Samsung lamp fan 0.14a, 2 ball bearing, 2000rpm, 92mm x 92mm x 25mm, 3 pin (red, yellow and black). If you buy a fan other than the Samsung original you will have to splice the wires of course Total cost of a compatible fan ranges from $3 to $10. DO NOT GET A SLEEVE BEARING FAN.
Televison & Video Logo
low speed fan
low speed fans go bad on all the R50 - R53's. It's very common. The resistors go bad and they're built into the fan . The whole unit will be replaced. You can get them online for a pretty good price, quite a bit cheaper than mini sells them. It's a bit of a job to replace, it takes a couple hours. You have to pull the bumper off,etc.
Oct 30, 2013 | Mini Cooper Cars & Trucks
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new controller is fine except the motor hums slightly. The electrician said that this is normal in some fans. The fan is a 900mm Stainless Steel, Aloha Model 207021 240 V 50 Hz x 120W 60 W motor. Can you please advise if the Fan Speed Controller is suitable for the Fan, or is it not possible to install a variable speed controller with this fan? Regards, David
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Feb 28, 2009 | Hunter Ceiling Fan Remote Receiver...
sony kds 50a2000 power light blinking
Your lamp has blown. You can order the lamp from Sony and replace it yourself. You can purchase the lamp here:
http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Other vendors also sell this lamp at a cheaper price (check the net)
Aug 07, 2008 | Sony KDS-50A2000 50" HDTV
731 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
