Tip & How-To about Computers & Internet
Eeepc 701-sd and linux
If you cant get you things printed because the bottom of the window is not showing try the "tab" button to estimate where the "print box is--then press enter and your document wil print
Computers & Internet Logo
Where do I go to find how much ink has been used
To check the ink levels from the printer control panel
1. Press Setup.
2. Press the down arrow button to highlight Tools, and then press OK.
3. Press the down arrow button to highlight Display Ink Gauge, and then press OK.
The product displays a gauge that shows the estimated ink levels of all cartridges
installed.
4. Press any button to return to the Tools menu.
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the ink cartridges appear.
Replace the ink cartridges
Apr 14, 2012 | HP Photosmart C6380 All-In-One InkJet...
can't get duplex printing
In Windows,
1.Go to your Start Menu> Devices and Printers>Right click on your default printer MP 210.
2. Right click on printing preferences. This will bring up the printing preferences window with 5 tabs with the Quick Set Up tab showing.
3. Under the "Additional Features" on the left side: You will see an empty box next to "Duplex Printing" Click on it to put a chck in the box.
4. At the bottom right hand corner you will see the Apply button is black. Click on it.
5. Click on OK.
Apr 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
how do i check the ink levels
To check the ink levels from the control panel
1. Press Setup.
3. Press the down arrow button to highlight Display Ink Gauge, and then press OK. The product displays a gauge that shows the estimated ink levels of all cartridges installed.
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
2. Click the Estimated Ink Level tab. The estimated ink levels for the ink cartridges appear.
Dec 08, 2010 | HP Photosmart C6380 All-In-One InkJet...
how to check the ink level onC4480 printer
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
146 people viewed this tip
David Payne
David Payne
