Tip & How-To about GPS
How to reset your Garmin Edge 205 or 305
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
GPS Logo
used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it on. Now the unit won't power on.
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
My Edge 305s GPS is not working. Everything else runs perfectly fine, it just will not acquire any satellites. I tried a soft reset. It won't let me hard reset though.
Hard reset is not very easy, so follow carefully instructions above.
Now simple advice, did you check in your parameters that the GPS transceiver is turned on ?
There is a mode with GPS off, don't ask why ...
Refer to your manual to find the menu.
Nov 22, 2010 | Garmin Edge 305 GPS Receiver
garmin edge 705 will not turn on
Nov 08, 2010 | Garmin Edge 705 Handheld GPS Receiver
Sorry but honestly...Since GARMIN launch the EDGE this problem is still not resolved by them. The EDGE 305 had the same problems. Just search the www and you will see. My 705 died on me after just 2 months.....Maybe better without it than having a unit dying on you while out on a ride. Tired visiting agents to replace EDGE units. When will GARMIN be able to fix this ????
Edge 205 or 305 or 705 or 605 often crash, then impossible to power on again.
Nov 01, 2010 | Garmin Edge 705 Handheld GPS Receiver
My garmin 305 edge won't turn on. I had it for about 2 years.
Try soft reset first then hard reset if not solving.
Soft reset : hold lap/reset and mode key for some seconds
hard reset : hold on/off and mode, then pulse on lap/reset.
after soft reset, hold start button for 10 secs before device starts again.
May 15, 2010 | Garmin Edge 305 GPS Receiver
2,008 people viewed this tip
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
