Tip & How-To about Cell Phones
How to Format Nokia Mobile Phones 3110c, 2700c, 5800 and Others
Detailed guide to Format your Nokia phone at home no need to take your mobile to service center.
This is already tested by me on many of the Nokia mobile.
Here is the model number of mobile which are success fully Formatted by this tool
Nokia 3110c, 2700c, 6120c, 3500c, 5800, 7210c etc. so no need to worry about any thing.
Which are the problems can be solved:
  • Music Player problems.(Updating and Music not found).
  • Display blinking problems.
  • Phone Restriction.
  • Slow mobile problems.
  • Software Missing(like Calculator, Currency Converted etc.).
  • Showing Corrupted Software Problem.
  • And many other problems.
Requirements :
  • A PC with atleast 512 MB RAM
  • Original Nokia Data Cable
  • Flashing Software. (We will be using Phoenix). Click Here to Download.
  • Nokia FirmWare
To Download Firmware for your mobile click here
Before Starting we need to uninstall the Nokia PC suite.
Lets Start the steps to Format Nokia mobiles.
Step1: Download and install Phoenix.
Step2: Install the Firmware downloaded from BLUE-NOKIA.
If you don't know which firmware is for your mobile, Press *#0000# on your phone and check the RM-XXX. The XXX represents your Firmware.
Step3: Run PHOENIX. (Make sure to exit Nokia PC Suite before running Phoenix)
Connect your phone with PC and PC Suite Mode.
Wait for the confirmation message from Windows that drivers are installed successfully.
Step4: Now in Menu bar click on File ? Scan Product.
Phoenix will scan your mobile information after scanning the product it will show mobile information on status bar.
Step5: Click on Flashing ? Firmware Update. As you can see below in the image click on browse(....).From the given list select your product code and click ok.
Don't know your mobiles product code?
Switch off your mobile phone remove battery. The product code is printed on the white label beneath the battery (e.g. CODE: 0520521).
Step6: Now Click on Refurbish, the phoenix will start formatting your mobile.
(Note: If at the time of formatting power cut problem occur than phone may get damage. The you will have to take your mobile to Nokia Service Center).
Formatting will take 10-15 Minutes so be patient do not remove data cable during formatting.
Step7: After Formatting Disconnect your mobile phone and you can see all the problems are gone.
Your mobile is now working like when you have purchased is.
Rate this if u like
Please comment below if you have any problem.
My website: meramobi.info
Cell Phones Logo
nokia 3110c is not switching on only 3 time flash
It is a software problem.So contact nearest mobile repairing shop to flash it with latest software version of software.100%OK
Aug 19, 2010 | Cell Phones
How to format Nokia 3110c
The above given does not work it only work on s60 mobiles for s40 mobiles like 3110c, 2700c, 6300 etc.
to format s40 mobile u have to take ur mobile to nokia care they will charge 200 to 250 Ruppes..
i found new way to format the mobile at ur home
http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.html
Aug 11, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c won't start it just show the nokia screen then it flashes white screens 3 times the it will go off
hey frnd your mobile software is corrupted you have to format you mobile by using flashing softwares here is the simple tutorial to formate the mobile <a href="http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.html">click here</a> <div><br /></div> <div><a href="http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.htm">http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.htm</a><br /> <div><br /></div> <div>or if you dont have knowledge of this you can take your mobile to nokia service center they will format the mobile and will charge 250-300 rs.</div> <div><br /></div> <div>hit thanks if you like</div></div>
May 20, 2010 | Nokia 3110 Cellular Phone
how to format my nokia 7210 supernova???
MY NOKIA 7210 SUPERNOVA MOBILE IN MUSIC PLAYER "OPERATION FAILED" ERROR
Apr 14, 2010 | Nokia 7210
nokia 6030..way to unlock
If your asking for the unlock code to use other simcards on it, you would have to request it through your service provider. However if phone is asking for a security code, Factory default security code for nokia's is (12345), but if you've already set up a security code on it you might want to contact manufacturer at Nokia Care Contact Center at 1-888-NOKIA-2U (1-888-665-4228). Send an e-mail Also, please reference the on-line tutorials, user guides and FAQs.
Sep 05, 2009 | Nokia 6030 Cellular Phone
7,470 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
