Tip & How-To about Toshiba Satellite P105-S9312 Notebook
I cant type @, # and ~
Everytime I try to type @ (shift - 2), " comes out instead of @. The same problem for typing ~ (shift - 1) and # (shift 3), but other comes out. Any solution?
My Toshiba Laptop is P105 Professional Premium Series.
Thanks in advance.
Toshiba Satellite P105-S9312 Notebook Logo
what transmision does the Taurus have
that depend on a few things .like what do you have andF}}}400}1086932" CHECKED="" type="radio">A.T., (6-183, 3.0L), DOHC (VIN S), (AX4N), col shift
A.T., (6-183, 3.0L), DOHC (VIN S), (AX4N), floor shift
D}}}400}1086934" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AX4N (code X), col shift
E}}}400}1086935" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AX4N (code X), floor shift
C}}}400}1086936" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AXODE/AX4S (code T or L), col shift
A}}}400}1086937" type="radio">A.T., (6-183, 3.0L), OHV (VIN U, 1 or 2), AXODE/AX4S (code T or L), floor shift
Jan 01, 2013 | 2000 Ford Taurus
C:\PROGRA~1\MYWEBS ~1\bar\2.bin\m3plugin.dll This error comes up everytime I start my laptop, I've looked at some solutions and it comes from MY Web Search, but when I try to uninstall the prog,
Go to Start - Run and type MSCONFIG then press Enter and choose either Services or Startup to try to identify which application may be loading m3plugin.dll and uncheck it
Apr 10, 2012 | Microsoft Windows Vista Ultimate Edition
when i am typing @ cant instead @ the letter is " please help
The keyboard is set up wrongly or the laptop isn't one set up for your country.
If you get " when typing @ try typing SHIFT and 2 for the @ symbol.
You can change keyboard settings in Control Panel.
Feb 13, 2011 | Toshiba Satellite A60 Notebook
how do i type in a fraction? it comes up like 1¬2 instead of 1 - 2 please help thnx x
You are in "Linear" input / output mode. Press [SHIFT] [MODE] [1] to configure your calculator to use "Math" input / output mode instead.
Jan 11, 2011 | Casio FX83ES Scientific Calculator
I can't type @, # and ~ on my laptop
You may have your NumLock enabled. That will make you type whatever blue characters are on the keys instead. Press your NumLock (sometimes Num Lk) button and see if that helps.
If that's not the case then you probably have the wrong keyboard profile enabled in Control Panel. (Thinks you are using a foreign keyboard layout of some sort.) If the above solution doesn't wok, open up the Regional and Language Options from Control Panel, select the Languages tab, and press the Details button under the Text services and input languages section. Make sure everything in there applies to you.
May 13, 2008 | Toshiba Satellite P105-S9312 Notebook
2,264 people viewed this tip
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
