Tip & How-To about Computers & Internet
How to send a file from Laptop to your Cell
Hi there!
First you need to pair your laptop with cell. Open bluetooth in your cell, Search the devices,select your laptop, it will show the name/model no of your laptop inside the bluetooth application in cell,
Assign a passkey and then you will see a msg in the laptop tray," a bluetooth device trying to connect, Click here to connect".
Now click on this pop up in laptop, enter the same pass key as you have entered earlier in cell and now you are paired.
Go to the file you want to send in side your laptop, right click on the file and select 'send to' Select bluetooth and then you need to search and select your device inside the pop up menu, once selected, you can receive the file inside inbox of your cell. cheers!
Computers & Internet Logo
Dear sir, i want to cennect my nokia 5233 handset to nokia bluetooth headset BH-108, how to cennect? kindly advise
Hi Surendrakait,
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
  1. Switch off your bluetooth device and switch off your cell phone,
  2. Switch on your cell phone and then open bluetooth and make sure it's active and is not in hidden mode.
  3. Now make sure that the bluetooth is fully charged and then switch it on.
  4. Search for devices from your cell phone , use the pair option in bluetooth connectivity , and add a new pair or create a new pair.
  5. Then the phone will search for the bluetooth and will detect it , and since this is the first time it will ask you for a pass code , you need to enter default 0000 and then select ok and then the bluetooth device will be paired and hence now you can use bluetooth.
Hope this helps ...:) In case you have any queries , feel free to contact me.
Sep 14, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
e52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
i want to send a file from my hp pavilion dv6000 laptops by bluetooth to mobile but it give a error An address incompatible with the requested protocol was used.i am using vista. what can i do?
first you need to pair your laptop with cell. Open bluetooth in your cell,search the devices,select your laptop inside the bluetooth application in cell, assign a passkey and then you will see a msg in the laptop tray," a bluetooth device trying to connect, click here to connect". now click on the pop up in laptop, enter the same pass key and now you are paired. go to the file you want to send in side your laptop, right click on it ad select 'send to' select bluetooth and then you need to search and select your device inside the pop up menu, once selected, you can receive the file inside inbox of your cell.
cheers!
Sep 04, 2010 | Computers & Internet
SHOW ME HOW TO PAIR N70 nokia phone
first go to bluetooth option then select search device then select that device then pair then enter the password 0000 or 12345 and then done
Dec 25, 2007 | Nokia N70 Cellular Phone
122 people viewed this tip
David Payne
David Payne
