Tip & How-To about Washing Machines
How to fix a Washing Machine if it is leaking
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is oversudsing, which can cause it to overflow. Reduce suds by pouring in 1/2 cup white vinegar in 1 quart water. Then switch to either less detergent or a low-sudsing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repairperson.
Washing Machines Logo
water is leaking from the injector hose is the injector need changing or could it be plugged?
If I got the issue correct the washing machine is leaking specially from the injectore.
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing machine supply hoses burst, Be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days.
2) Determine whether the machine is oversudsing, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-sudsing variety.
3) the machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repair person.
Thank You for contacting fixya.com
Oct 12, 2009 | Kenmore 22422 Top Load Washer
Washing machine is leaking while filling and before rinse
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repair person.
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
leaks behind the ciment cast
If I got the issue correct the washing machine is leaking specially from the in front of your top loading washing machine.
2) Determine whether the machine is overwashing, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-washing variety.
Oct 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
it is leaking under the washer tub
Oct 12, 2009 | Washing Machines
leaking water out of the bottom
Oct 12, 2009 | Frigidaire FWS833A Top Load Washer
265 people viewed this tip
Top Washing Machines Experts
