Tip & How-To about Washing Machines
How to fix a Washing Machine if it doesn't Drain
If your washing machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is fine (though some units have a separate belt for the pump, and direct-drive washing machines don’t have belts.)
1) Be sure the drain hose isn’t kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The water pump may be broken or clogged with a small article of clothing, or the controls may be broken; call an appliance repairperson.
Washing Machines Logo
washer will not extract in the spin cycle
f your washing machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is fine (though some units have a separate belt for the pump, and direct-drive washing machines don't have belts.) 1) Be sure the drain hose isn't kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
Dec 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a GE washer that won't drain!
The pump is clogged. Remove the tub to pump hose and you will find debris in it not letting the pump work. Do this and you will be good to go. Thanks, Rick
Mar 04, 2010 | Washing Machines
washer agitates but doesn't spin or drain
something in your pump lean it back take hose off drain pump and clean it out
Dec 31, 2007 | Kenmore 49722
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
No draining
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
405 people viewed this tip
Top Washing Machines Experts
