Tip & How-To about Washing Machines
How to fix a Washing Machine if it Doesn?t Agitate
If your washer fills with water but doesn’t agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.)
1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn’t, the belt may be loose or broken. If you’re fairly handy, tighten or replace the belt; otherwise call an appliance repairperson.
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) There may be a problem with the controls, or the agitator solenoid may be broken. Call a repairperson.
Washing Machines Logo
Washer will fill with water and then pops the circuit breaker
see the causes:
t doesn't pump or spin
frozen puller+ belt broken replace
It pumps, but doesn't spin
lid swithc broker or open,motor coupler broken,belt broken, and clutch worn,drive motor defective,transmision not shifting properly,basket driven worn.
It spins only with the lid closed lid switch prevent the action to start.
see the diagram
Jun 19, 2012 | Washing Machines
admiral washer will not spin but does agitate.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely -if it's frozen or stiff- replace it.
a.- It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
a.1. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
a.2. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.- It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
b.1. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.2 The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
b.3 A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
b.4 The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
b.5 The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
b.6 The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
b.7 The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
c.- It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Additional details in Admiral: Washer Use and Care Guide (PDF Format)
Check it and keep us updated.
Oct 10, 2011 | Admiral AW22 Top Load Washer
washer fills but won't agitate
What brand and model#? Everyone is different. Some quick checks, belt not broken, electronic motor (unplug for 2 minutes, replug in, open and close lid slowly 7 times to reset motor.
Aug 16, 2009 | Washing Machines
Washing machine doesn't agitate
If washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. Note: direct-drive washing machines do not have belts. 1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn't, the belt may be loose or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) Call a repairperson; there may be a problem with the controls or the agitator solenoid may be broken.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
252 people viewed this tip
Top Washing Machines Experts
