Tip & How-To about Nintendo Wii Console
Nintendo wii Error Code 61070 fix
Error Code 61070
  • Make sure that your Internet connection is compatible with the Wii console's online service. You must have broadband Internet (Cable, DSL, or Fiber Optic) and a compatible wireless router. For more information, click here.
  • If you have verified that you are using a compatible Internet connection, then it appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies
Nintendo Wii Console Logo
error code 32002
From the Nintendo Website -
Error Code: 32002
Lost connection during Wii system update
Likely causes: Your Internet connection has slowed or was interrupted, or our servers could be busy.
Verify the following:
Slow or incompatible Internet connections can "time out" and result in this error code. Are you using a broadband Internet connection such as DSL, cable, or fiber optic? Other, slower types of connections, may not be compatible. Click here for more info about compatible connection types. Try the following:
Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.) Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area. Manually change your Wii console's DNS settings. To do this, follow these steps: Access the Wii system settings (how to), and use the right arrow twice and select "Internet." Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS." Select "No," and choose "Advanced Settings." Click into the "Primary DNS" field and enter: 8.8.8.8 Click into the "Secondary DNS" field and enter: 8.8.4.4 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
Select "Confirm," and then "Save." Select "OK" to start the connection test. Once the test finishes, try to download the update again. Our servers may be busy, especially if a new update for the Wii system is available. Wait at least a couple of hours and try to download the update again. If after waiting several hours you are still receiving this error code, please call 1-800-255-3700. If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
Mar 19, 2011 | Nintendo Wii Console
I plugged in my wii LAN adapter and tried to test it but didn't work?Wired Connection
Make sure you are using the Wii lan adapter made by nintendo
  1. Make sure you are using a "broadband" internet connection, such as high speed cable or DSL. Slower connection types, such as dial-up, may not work properly with the Wii console. If you are unsure what type of connection you have, please contact your Internet Service Provider (ISP) for more information
  2. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
  3. Your access point (wired router, broadband modem*) may have certain firewall settings that are preventing a successful connection.
better u download repair guide
click here to download repair guide
Dec 16, 2010 | Nintendo Wii Console
im try to connect my wii online but i get error code 51330 saying unable to connect to internet. im on wierless and have con though connection and his comes up after testing my connection.....what should i do to get it online?
Error Code: 52130 There appears to be an issue with your wireless router's firewall.
  1. Make sure your router is not listed on our "known incompatible routers" page, by clicking here.
  2. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
    4. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  3. Disabling your router's wireless security may help the Wii console's online connection. Consult your wireless router's manual or check with the router manufacturer for more details. Please note Nintendo provides these recom mendations as a resource to our consumers; it is up to each consumer to determine if adjusting their router's security settings are the right choice for their home network.
  4. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
Feb 03, 2010 | Nintendo Wii Console
getting error code 107305; unable to connect to linksys router
Error Code: 107305 If your recently received a system update, and use a router that has an SPI firewall that may not be compatible with the Wii console (click here to view a list of known routers), please note that access to the News, Weather and Everybody Votes channels, as well as any channels that utilize the WiiConnect24 feature, may be inaccessible or have limited function with this update. A future Wii console system update is in development that will enable the use of all of the Wii console's online features. Please check back for more information.
If the above information does not apply to you, please try the following steps to resolve the issue you are experiencing:
  1. Our servers may be busy. Please wait and try again later.
  2. Check the internet Connection Settings of your Wii console. If you need assistance, we can walk you through the process using our step-by-step guide that allows you to follow along. Please click here to begin.
  3. Some routers and Internet Service Providers may not be compatible with the Wii console's ability to connect online. Check to see if your router or ISP is incompatible by clicking here.
  4. If you are still receiving this error code after waiting at least 24 hours, and have confirmed your Wii console's Internet Connection Settings are correct, please call for assistance.
Oct 07, 2009 | Nintendo Wii Console
Wii wired internet connection problems
if you have all of these
Requirements to Connect the Wii Console Online with a Wired Connection In order to connect the Wii console online with a wired connection, you will need the following:
  • A Wii LAN Adapter (where to buy)
  • An active broadband internet connection, such as DSL or Cable.
  • A compatible Internet Service Provider (ISP). Some ISPs require a sign-in every time you connect online, or are otherwise incompatible. Contact your ISP for more information.
  • Either a cable modem or wired router with an available ethernet port. (DSL users: while some DSL modems may be compatible, our experience has shown that many are not. We recommend using a router.)
  • An ethernet cable.
then go here for more information
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
this information was found on nintendo's customer service website
I hope you find it useful
Dec 29, 2008 | Nintendo Wii Console
892 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
