Tip & How-To about Office Equipment & Supplies
Clean glass tip for copiers in general
Keep your glass Super clean.
If you can access Both sides of the glass, that is even better.
Be sure to use LINT free cloth to clean the glass with.
DO NOT use Tissues -- tissues are made of wood fibers which cause small scratches on the glass and mirrors.
IF you can get to the mirrors, Super carefully clean them, also -- again with LINT free SOFT cloth...(do not leave finger prints on them).
(do not leave finger prints on glass, either -- at any time.)
(if this has been helpful, please rate my tip help++++Thanks for using FIXYA)
horizontal lines/missing print occurs on my pages. I have tried to reboot the printer, but the printing issues remain. Do I need to clean the print heads?
Follow these steps to make it work... TIP: Focus on the printer it self. make sure that it can copy (b&w and color) fine.
If your done reseting the printer go to the next step Solution #2 Clean the All-in-One and make a blank copy Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the power Button to turn off the product, and disconnect the power chord at the back of the printer.
  2. Open the scanner lid, and remove any originals from the scanner glass.
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth.
Step two: Clean the automatic document feeder ADF
  1. If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
  2. Locate the ADF frame to the left of the white underside of the scanner lid.
  3. Press the ADF frame release.
  4. Unhook and remove the ADF frame.
  5. Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
  6. Use the dampened cloth to clean both sides of the transparent film, and the white strip in the center of the ADF frame.
  7. Clean the ADF frame.
  8. Re-Install the ADF Frame
Step three: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
  • If the copy is clean, there is no need to continue troubleshooting.
  • If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. Contact HP's Printers support department @ 1-800-474-6836
To view this steps w/ images click on this link Good luck! :)
Feb 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
i have lines in printed material
If a print result of faxing, copying or scanning has uneven print density, or when copies and scans you make have vertical black lines, cleaning the platen glass may solve the problem.
  1. Turn off the power and disconnect the power cord.
  2. Prepare two clean, soft, and lint-free cloths.
    Note:
    Do not use tissue paper or paper towels as they may damage the machine.
  3. Open the document cover.
  4. Wipe the platen glass (D), the inner side of the document cover (white area) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) with a clean, soft, lint-free cloth moistened with water
    (A) ADF Glass
    (B) ADF White Reference Area
    (C) Document Cover White Reference Area
    (D) Platen Glass
    Note: If you have trouble wiping dirt, use diluted mild detergent (for dish washing).
    Caution:
    * Never use volatile liquids such as thinners, benzene, or alcohol; these can damage the machine.
    * The d
    ocument cover white reference is easily damaged, so wipe it gently.
  5. Carefully wipe away moisture from each part with another soft, dry lint-free cloth. Do not leave any residue, especially on the platen glass.
  6. Close the document cover.
  7. Reconnect the power cord and power the machine back on.
Oct 26, 2010 | Canon MP830 All-In-One Printer
bought a new drum and cartridge for brother dcp-7040. with new cartridge printing huge blotches, extra toner all over the page... old cartridge prints fine.
I hate to be the bearer of bad news, I used to be a copier repair tech. I think you need one -- badly. I think you have 'contaminated' the unit if it started doing this w/new cartridge.
If you can retrace your steps and remove the drum and cartridge, and clean, clean, clean --everything you can see -- even the tiniest speck gets magnified.
If you can get to the mirrors, be sure to use lint free cloths on them. Do not scratch those babies, or you are toast. And get the ALL the glasses all super clean, on both sides of the glasses, if possible.
You might have to stand on your head, and find places you never thought you'd ever see.
This isn't step-by-step, but, if you put in the drum and cartridge, you Have a manual, right? This info tells you what the manual doesn't. right? and I wish you the best. Do not try to rush. Be sure to have the power off, keep a little extension magnet/mirror-tool handy to catch screws that roll away from you. Might need some 'tiny-screw-drivers' also.
and I wish you the best. Do not rush.
Aug 12, 2010 | Brother DCP 7010 Multifunction Laser...
verical line(s) problem with canon mp780
Hi Nick, It's ONLY when you copy? I start by cleaning the platen glass. Wipe the Platen Glass with a clean, soft, lint-free cloth moistened with water. Then wipe with a clean, soft, dry, lint-free cloth making sure not to leave any residue, especially on the Platen Glass. If you have trouble getting the scanning area clean, wipe with diluted mild detergent (for dish washing). Do the same thing for the white area under the platen lid. If this does not resolve the problem let me know. His Dudeness
Nov 15, 2006 | Canon PIXMA MP780 All-In-One InkJet...
256 people viewed this tip
jasbo
jasbo
