Tip & How-To about Refrigerators
How to fix a Refrigerator that Doesn?t Cool or Runs Constantly
If the refrigerator’s light works and you can hear the refrigerator running but it cools poorly or does not stop running, make sure nothing is blocking the passageway between the freezer and the refrigerator compartments. If airflow is restricted by, for example, a loaf of bread situated in front of the passageway, the refrigerator won’t get cold. Be aware that a refrigerator will tend to run longer when it’s full of food, the door is opened frequently, or the room temperature is hot.If your refrigerator runs without stopping, it may be low on refrigerant and cannot reach the low temperature that the cold control dial summons. More likely, it is a defrost problem in which a component in the automatic defrosting system is faulty. This could be a defrost heater, a defrost timer, or a defrost terminator.
Before you call a repairperson, do the following:
1) Determine whether the refrigerator section is being cooled. If you see frost at the top of a “frost-free” refrigerator even when the cold control is set low, it means the refrigerator probably has a full charge of refrigerant and it is the thermostat that is faulty or out of calibration.
2) Try turning the cold control both up and down. If the compressor doesn’t shut off, the cold control may be broken. Call a repairperson. During the repair, it is a good idea to have the defrost timer and heaters checked to ensure they are working correctly.
3) Look at the condenser coils, located at the bottom of the refrigerator (behind the kick plate) or, in some cases, at the back. These coils disperse heat from inside the refrigerator out into the room with the aid of a fan. If the coils are dirty, the refrigerator won’t operate efficiently. You must clean them regularly.
4) Make sure the drain line under the evaporator coils, which goes to a pan underneath, is not plugged up (water should drip into the pan when the refrigerator is defrosting).
5) To put off having the refrigerator repaired for a few days, you may be able to defrost it manually with a hair dryer—if you can access the cooling coils in the freezer section. Excessive moisture in the coils can turn into a frozen mass, reducing efficiency. Be very careful when using the hair dryer near a water source as there is a serious risk of electrical shock. Also be careful not to melt the plastic parts.
Refrigerators Logo
Samsung Refrigerator Stopped Cooling months after New Compressor Was Installed
Corrosion is caused by the acidic flux used to make the solder flow. If the joints are bad, it is probably out of gas due to leaks.
Oct 07, 2015 | Samsung Refrigerators
GE Profile Refrigerator PSS26SGPSS stopped cooling on both fridge and freezer side. Temp controls show current temp (now 78), but when I set for lower temp, nothing happens. Hear small fan running, but no sound of condenser. All lights and displays are working and appear normal.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 01, 2011 | Refrigerators
nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
If the refrigerator's light works and you can hear it running but it cools poorly or runs without stopping, any of several problems may be at fault. First, make sure nothing is blocking the passageway between the freezer and refrigerator compartments--if airflow is restricted by, for example, a loaf of bread situated in front of the passageway, the refrigerator won't get cold. Be aware that a refrigerator will tend to run longer when it's full of food, the door is opened frequently, and the room temperature is hot. If your refrigerator runs without stopping (unless you turn it off), it may be low on refrigerant. Without a full charge, it cannot reach the low temperature that the cold control dial summons. More likely, it is a defrost problem in which a component in the automatic defrosting system is faulty. This could be a defrost heater, a defrost timer, or a defrost terminator. Before you call a repairperson, do the following: 1) Determine whether the refrigerator section is being cooled. If you see frost at the top of a "frost free" refrigerator even when the cold control is set low, it means the refrigerator probably has a full charge of refrigerant. If this is the case, the thermostat may be faulty or out of calibration. 2) Try turning the cold control both up and down. If the compressor doesn't shut off, the cold control may be broken. Call a repair person. During the repair, it is a good idea to have the defrost timer and heaters checked to ensure that they are working correctly. 3) Look at the condenser coils, located at the bottom of the refrigerator (behind the kick plate) or, in some cases, at the back. These coils disperse heat from inside the refrigerator out into the room with the aid of a fan. If the coils are dirty, the refrigerator won't operate efficiently, so clean them. 4) Make sure that the drain line under the evaporator coils, which goes to a pan underneath, is not plugged (water should drip into the pan when the refrigerator is defrosting). 5) To put off having the refrigerator repaired for a few days, you may be able to defrost it manually with a hair dryer-if you can access the cooling coils in the freezer section. Excessive moisture in the coils can turn into a frozen mass, reducing efficiency. Be very careful when using the hair dryer; do not stand in a puddle of water--there is a serious danger of electrical shock! Also be careful not to melt the plastic parts.
Jan 18, 2006 | Hoover HCA331FFK
660 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
