Tip & How-To about Audio Players & Recorders
How to get good quality of sound in home theatre system
Always maintain speaker level above 6ft.make sure that u r surrounded by speakers.there must be a gap of atleast 66 cm from speaker to speaker or more.bass must be always 75%.treble must be 100%.connections must be good.no cuts and joinings must be there in middle.
subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Can Acoustic Research wirless speakers be used for surround?
yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Jan 28, 2009 | Acoustic Research 900MHz Wireless Stereo...
I'm installing a surround system in my basement. My question is where else can i install my center speaker? I'll be installing an electric fire insert with a large T.V. above on a 6ft stone tile wall. I'll have built-in shleving on either side of the stone tile wall, for my left/right speaker, but don't want that center speaker to be an eye sore. Any suggestions?
Hi, you can tell your amp there is no center speaker and the sound will be diverted to the left and right or for better sound if you can get a custom install speaker built into the wall or if the tv is high up on the wall put your center in the ceiling.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
268 people viewed this tip
 Grubhead
Grubhead
