Tip & How-To about Refrigerators
How to Remove scratches outside refrigerator door
This tip is only for small scratches which are like hair sized one not more than that,If you have deeply scratched panels,you have to hire a professional to refinish them.
Today most of the refrigerator door come in stainless steel based plastic door.You can easily remove the small scratches on these door.
Steps to be followed:
1)Take white cloth and it should be a soft and dry one.
2)Buy stainless steel polish and squirt it on a small cloth and rub over the scratched area.So that it will get pasted over it.
3)Rub in one angle and in same direction.
4)Now rub the scratch with scouring pad over the surface of the polished scratch.
5)Buff with a clean cloth and remove the small particles so that it wont make more scratches.
6)Wait for 3 hours and take some water dipped cloth and wipe on it.
7)For deep scratch you have Teflon coating so that no more scratches will occur and also removes the deep scratches.
Refrigerators Logo
scratch on the front panel, how do we repair. Does it have to be replaced?
Scratches aren't an easy or inexpensive fix. However, if, like most appliances, your's has a protective clear coat on it, you can try using a small applicator (like a Q-tip swab, etc.) and a very, very light amount of clear lacquer and lightly dab it onto the scratch and quickly wipe off the excess with a clean, lint free, cloth.
You can buy a can of clear aerosol lacquer that closely matches the type of finish on the fidge panels, (matte, satin, gloss).
The trick is to NOT spray directly onto the panels, but rather spray a small amount into the cap of the aerosol and using the swap, dip it into the liquid and, again, dab it lightly onto the scratch.
Another option is to purchase one of those automotive scratch repair kits that you see advertised on TV or in auto parts stores and follow the directions for fixing the scratch.
If you take your time and go lightly and carefully with the application, you can get a pretty decent repair that will make the scratch all but disappear. If it's also dented, then you've got another issue to deal with, but in any event, attempting a repair of the scratch will cost you hundreds of dollars less than buying a replacement door panel.
I hope you find this Very Helpful and best regards!
Oct 14, 2009 | KitchenAid KSSC36FMS Side by Side...
How do I fix a deep scratch on the screen, it is a wide scratch,maybe like a small toothpik size, when black background is on, it shows as a white scratch, I have tried vasoline, but it does not fill in the scratch. Any other things I can do?
Unfortunately there isn't anything you can do. The LCD surface itself has been physically damaged and no longer works properly. This isn't simply a scratch. The only solution is to replace the display panel, and they are nearly impossible to find unless you are an authorized servicer working on a warranty repair. There are companies that sell parts removed from sets, but most sets are junked because of bad displays. Since the display is the single most expensive part, if you can find one it may not cost much more just to replace the TV. There's always a sale going on somewhere, and many online vendors as well.
Jun 10, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Scratches in my LCD Television Screen (sony bravia) How will I fix this?
Easiest solution is the stuff you buy to fix your glasses with (Lens cpr), so long as it's a small scratch. Larger scratches don't try to fix you can damage the screen further.
Other solutions (though I recommend only at your own risk)
Vaseline Method
Clean the surface of the screen.
Take some Vaseline and fill the scratch with it.
Gently wipe off the excess Vaseline, being careful not to press too deeply so as to leave some inside the scratch.
Voila. This works because the optical density more closely matches the LCD face than air.
Pencil Eraser Method
Find a pencil with a clean, soft eraser. It must have no pencil graphite on it as you won't want to smudge that on your monitor.
Lightly rub the eraser over the scratch or nick on the screen.
Keep rubbing until the scratch completely disappears [1].
Sep 02, 2008 | Televison & Video
Scratch on LCD screen of the monitor
Unfortunately, most lcd panels have a polarization filter in the front, this looks like a plastic coating that is actually in front of the glass of the lcd panel, if it's scratched, there is no real way to fix this problem other than replacement.
Jun 22, 2008 | LG Flatron L1710S 17" LCD Monitor
thick plastic film covering glass screen got deeply scratched while moving
Hi there!
I would simply replace the plastic sheeting. Will certainly be cheaper than replacing a tube. Glass tvs don't normally come with this plastic so leave it off if you can remove it. There is a type of spray on the market for this purpose, just don't know if available in your country. Please note: It is dangerous to use a tv which had been scratched beyond 1.5mm, The glass may become unstable and implode if bumped by accident. Good Luck,JUS004
Mar 08, 2008 | JVC AV-32FA44 32" TV
1,128 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
