Tip & How-To about Electrical Supplies
Helpful diagnoses of the gas, air and spark of small engines.
Remove the spark plug and wile holding with a pair of pliers
ground the metal side of the plug against the top of the motor on a bare spot
set the run switch to run and crank the engine look for a spark if theirs a spark
re install the plug.
check the gas line at the carb by removing the
hose and turning on the gas valve under the tank.
if gas flows then replace the hose back.
if theirs no gas then you have a plugged fuel line or gas valve
their is also a screen in the tank attached to the valve remove it and install a in line filter
it will be easier to replace later if it happens again.
remove the air filter and crank engine with the choke closed
check for a gas smell in the carb hole by smell after cranking engine.
if wile checking for a smell of gas at the carb and their was none then you can have a stuck float or
gummed up carb remove and dissemble clean and at that point rebuild the kits are only around $20.00 and a float $6.00+.
if ok remove the spark plug again and set run switch to off
place a finger over the plug hole crank finger should be blow-en from the hole
and a wosh of air if ok. go to next step.
if the pressure did not blow your finger off you may have a stuck valve or a bent one
this will require removing the head for repairs.
take in for service.
if there is no spark with plug removed remove wires from the run switch and connect
together and remove wire from the low oil sensor crank. if spark replace the wire back
on low oil sensor crank if no spark replace the low oil sensor reassemble run.
if the is no spark with the wire on the sensor then replace the run switch.
re assemble run. if their is no spark with oil sensor disconnected and run switch wires
connected to each other remove the front air flow cover to expose the coil check wires for any
bare spots repair as needed. on the top on the flywheel theirs a coil their will be a spade plug
or a wire small that is a kill wire disconnect and crank check spark if spark then that wire is shorted
in the loop and you have to trace it it will go to a wire stud mounted to a plate under
the carb with a plastic mount this can be cracked and shorting bypass and try again still
no spark use a match book cover and lower the coil to the flywheel with the match book cover
in be tween and disconnect the small wire crank if no spark the coil unit is the issue replace
some people will say sand clean the tops of the magnets built in to the flywheel this is a myth
it don't matter but feel free to clean anyways it don't hurt.
this seams allot but it is a complete diagnoses the fuel,spark and air system if all this is ok and still don't run you have a serious internal issue the engine will either need
major work or replacement. i hope this all helps you.
Electrical Supplies Logo
1996 grand marquis will not start
will it crank at all? if its cranking there are three main things that make an engine run... fuel, air, spark. check spark by pulling a plug and keeping it plugged into the wire and holding the threaded part of the plug to a good ground(any bare metal on your engine will work) hold the spark plug wire boot with a pair of insulated pliers or a pair of gloves while doing this! have someone crank the engine while you do this. if you have spark you should see it jumping from the plug through the gap. if you are getting spark then check fuel delivery by cranking engine for a few long seconds then pulling a plug to see if it is wet with gas. i hope this helps
Jan 10, 2013 | Cars & Trucks
geting fuel getting fire but no starty starty
do you have a spark from the plug wire to the plug? take off plug wire get old plug hook it to wire be sure plug is touching a bare metal spot called a ground. crank motor or get someone to while you hold plug to metal plug should spark on tip no spark could be coil, ignition module check to see if you truck has an engine fuse. look in manual in dash god luck from sunny austin tx .
Feb 24, 2011 | 2002 Toyota Tacoma
i bought this generator it has been sitting for awhile and was low on oil on one side i added oil but still acant get it to start
remove the spark plug and wile holding with a pair of pliers
Sep 02, 2010 | Coleman Powermate Premium Plus 6250W...
my honda activa 2004 scooter is not at all starting it has starting problem plz give suitable troubleshooting for my problem.........
Only two things prevent an engine from starting/running. Always go to "Basics": Spark & Fuel (fuel/air mix). That's it. 1) Remove spark plug. 2) Put the plug back in in the "Spark Cable" just as it is IN the Engine. 3) Scrape a small area clean (down to bare metal) on the frame. 4) Hold the rubber head of the cable with rubber handled pliers (water pumps work great) using this to hold a side of the plug against the bare metal. 5) Turn the Ignition switch to ON. Crank the Engine as if starting it. Note the spark (if any). Is it Blue?=Strong Yellow?=Weak Is it Centered or way of to the side of the electrodes? If you have a good, regular, strong blue/white spark-...Fuel: 1) How old is the gas in the tank? Over 3 mos. Dump it! 2) Always replace/clean Fuel filter. 3) Same trick: Pull the fuel line off at the carb. and crank the Engine. (Careful-No Smoking!) Gas? 4) Fuel/Air mixture. If you have good Spark and good fuel...and Still does not start...Time to check parts. Good Luck
Aug 26, 2010 | 2005 Honda Activa
dont start
major work or replacement. i hope this all helps you. re-post your outcome please.
Aug 23, 2010 | Coleman Powermate Powermate 5000W...
1,866 people viewed this tip
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
