Tip & How-To about Computers & Internet
Computer Cannot read my SD Card
STOP SD MEMORY CARDS ARE NOT ALL THE SAME !This is a very common issue as of late because of the fairly recent addition to the market place with the "HC" and "XD" Cards. I have found most computer older than 2008 wont read HC and XD cards however I'm sure there are USB card readers that can fill this gap available at your local pc shop. Please look Carefully at these different formats Standard SD: 1 MB to 4 GB readable by almost all computers most often up to 2GB rarely up to 4GB
SDHC: 4 GB to 32 GB Most older Computers Cannot read the the HC format, good however for NEWER devices such as camera's, video cameras and recent phones (my cannon powershot S80 will NOT read HC format, nor will my 2007 laptop.)
SDXC: 32 GB to 2 TiB same limitations as above, Great cards for Digital Video Camera though!
here is a wikipedia note "Changes to the interface of the established format have made some older devices designed for standard SD cards (≤4 GB) unable to handle newer formats such as SDHC (≥4 GB). All SD cards have the same physical shape, which causes confusion for many consumers"
So.. in closing MAKE SURE your device supports HC and or XC before your purchase one! Also be aware that most of these cards have a lock switch on them to write protect the data, located on the side of the card. It MUST be in the Unlocked position to operate normally. Hope this helps someone out there. please use the thumbs up if it clears up anything for you! Gurvy
Computers & Internet Logo
my downloaded games on the android market was placed on the phone memory not on the sd card
So that the icon can be place at the phone screen. I't is o.k to do so. I't is the phone default. To make the apps more working. In this unit your SD card is more on storage file's like picture, music so on and so fort. except installed apps. you can download apps save it in SD but after installing, it will automatically save at the phone memory. If your phone memory is full? you have to uninstall some of the other apps.
May 02, 2011 | LG GT540 Cell Phone
what size memory card do i need
The most common SD card used for Vivitar Vivicam 3715 is the 2GB Standard Secure Digital (SD) Memory Card.
See its actual price in the online market from the link below.
http://www.amazon.com/dp/B0033ZEWPS/ref=asc_df_B0033ZEWPS1211148?smid=A1Z74S8KTUFMH9&tag=dealtmp3804-20&linkCode=asn&creative=395105&creativeASIN=B0033ZEWPS
Aug 12, 2010 | Vivitar ViviCam 3715 Digital Camera
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
Jun 15, 2009 | Pentax Optio E10 Digital Camera
finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Feb 20, 2009 | Fuji FinePix S700 Digital Camera
Additional SD card memory installed in the card slot
Check to see if it is the proper SD card. while several size ( memory) cards may fit the port the player may only recognise a 2 or 3 gig card.
Dec 30, 2008 | Creative Labs Zen Digital Media Player
1,456 people viewed this tip
David Payne
David Payne
