Tip & How-To about Computers & Internet
How to Install Compaq Laptop Keyboard
Compaq laptop keyboards have a variety of sizes and configurations to fit the design of the laptop itself like smaller laptops or larger laptops with full-size keys. You might now find that the keyboard or keypad exhibits problems such as sticking keys or general unresponsiveness from your owning Compaq Presario laptop because of several years'using. Besides, you have made sure that your old keyboad is clean but it still doesn't work well. Then you have to install a new one. So how to do it? Don't worry, you can DIY your Compaq new keyboard via this guide.
Step1. Exit Windows and turn off your computer.
Step2. Unplug the power cord and modem and network cables.
Step3. Place your laptop on a clean and disconnect the old keyboard. Open your laptop screen as far as you can.
If you are installing a USB keyboard, connect the keyboard to a USB port on the back of your computer.
Step4. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Compaq Keyboard in place.
Note: Keep these screws in a safe place.
Step5. Gently tug the Compaq Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
Step6. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right.
Step7. Connect the power on your laptop and verify that the new Compaq Keyboard is working.
OK, well done! Compaq keyboards are inexpensive, easy to find and quick to install. Actually, all Compaq Presario laptops have reasonable prices and you don’t have to worry if something breaks down as replacements are easy to find and cheap to buy from Papatek. Papatek Compaq Laptop Keyboard are specifically designed for each Compaq laptop brand and model.
Computers & Internet Logo
what is laptop
A laptop (also known as a notebook)is a personal computer designed for mobile use. A laptop integrates most of the typical components of a desktop computer, including a display, a keyboard, a pointing device (a touchpad, also known as a trackpad, and/or a pointing stick) and speakers into a single unit. A laptop is powered by mains electricity via an AC adapter, and can be used away from an outlet using a rechargeable battery. A laptop battery in new condition typically stores enough energy to run the laptop for three to five hours, depending on the computer usage, configuration and power management settings. When the laptop is plugged into the mains, the battery charges, whether or not the computer is running, with the exception of some laptops.
Portable computers, originally monochrome CRT-based and developing into the modern laptop, were originally considered to be a small niche market, mostly for specialized field applications such as the military, accountants and sales representatives. As portable computers became smaller, lighter, and cheaper and as screens became larger and of better quality, laptops became very widely used for all purposes.
Dec 22, 2010 | Computers & Internet
Full screen
Press the F11 button to get full screen.
To return back to normal screen, press the F11 button again.
You can also hold down the CTRL key on the keyboard and Scroll down the scrolling button on the mouse.
To revert to normal , again hold the CTRL button on the keyboard and scroll upwards.
Cheer
Uttam
Jul 12, 2010 | Advent Netbook
How do I fit extra memory in a compaq hp nc4000with the existing memory in place
There's a second memory slow behind the keyboard.
You'll need a small star shaped screwdriver, can't remember the exact size, and will need to undo 3 screws. one has a pic of a keyboard next to it and is pretty central, and then 2 more nearer the hinge end of the laptop. These last 2 will allow the grey strip with the LED's on to be levered out with a thin screwdriver. The keyboard will then come away, careful not to dislodge the ribbons, and this will expose the 2nd memory slot...
Oct 10, 2009 | HP Compaq Business Notebook nc4000...
how to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
Make my Compaq Presario Laptop Wi-Fi.
If the wireless card is about the size of a thick credit card then it is a PCMCIA card device. This card plugs into the PCMCIA slot on either the LH side or the RH side of the laptop. You need to install the wireless card driver on the laptop and configure it to communicate with your wireless router which is connected to your Internet Service Provider. This wireless card can also connect to the Internet on free WiFi sites. As you are a novice, you will need a computer savy friend to help you or your friendly computer shop.
Jun 10, 2009 | Compaq Computers & Internet
279 people viewed this tip
David Payne
David Payne
