Tip & How-To about Apple iPod touch
How to restore ipod touch after forgetting password.
Warning this will restore ipod back to original state! All apps downloaded will be deleted.
1.Plug ipod into computer. 2.When itunes load click your ipod name under devices. 3.Choose restore button and accept all prompts. 4.Will restore with newest update available.
Apple iPod touch Logo
i am locked out and i need to connect to iTunes
to fix this you, unfortunately, will need to erase all the data on the iPod.
plug the iPod into the computer using the included USB cable. open iTunes. Hold down the home and power buttons at the same time until it shuts down and reboots. (if it doesn't open automatically) in the column on the left side of the window there is an icon showing your iPod's name. click on it then click on the button that says "restore iPod"
WARNING: this will erase all the content on the iPod (you can put it back on when you are done)
it will ask you to confirm. hit "OK" and keep your iPod plugged in as it restores it to it original state. pick the language you prefer and then load your music back on the device.
Jan 12, 2011 | Apple iPod touch
i Forgot the 4 didget password. So when i turn it on it says IPod is Disabled and then it says Connect to itunes and i dont get how do do it. and how do u reset it with out Deleting anything on my iPod touch?
unfortunately it is not possible to reset the pass-code without erasing the entire ipod.
plug the ipod into the computer using the included usb cable. open itunes. Hold down the home and power buttons at the same time until it shuts down and reboots. (if it doesn't open automatically) in the column on the left side of the window there is an icon showing your ipod's name. click on it then click on the button that says "restore ipod"
WARNING: this will erase all the content on the ipod (you can put it back on later)
it will ask you to confirm. hit ok and keep your ipod plugged in as it restores it to it original state. pick the language you prefer and then load your music back on the device
Jan 09, 2011 | Apple iPod touch
how do i unlock my ipod touch
Sep 22, 2010 | Audio Players & Recorders
I HAVE A IPOD TOUCH AND IT DISABLED FOR 4989612 MINUTES
  1. Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
  2. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
  3. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
  4. When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
  5. After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
  6. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
WARNING:
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
Sep 27, 2009 | RCA TH1602 MP3 Player
forgot password
to fix this you will need to erase all the data on the ipod(s).
plug the ipod into the computer using the included usb cable. open itunes (if it doesn't open automatically) in the column on the left side of the window there is an icon showing your ipod's name. click on it then click on the button that says "restore ipod"
Jun 08, 2009 | Apple iPod touch
750 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
