Tip & How-To about Guess Joy Carpets Blue Colorific 6 x 9 Area Rug Watch
Carpet Stains
I have a blue rug in my living room. The other day bright green nail polish was spilled on it by our daughter.. My husband was ready to freak. I soaked the spot with nail polish remover and rubbed it with a damp rag. I then sprayed it with Woolite spot spray, rubbed in a circular motion and let dry. The rug is fine and there's no more stain.
Guess Joy Carpets Blue Colorific 6 x 9 Area Rug Watch Logo
I have 3 people in my house my husband in living room grandson in his room and me on my phone how do I get it to let 3 people watch different shows at same time
put separate tv's in each location and fit an antenna splitter (available from JAYCAR )in the antenna cable and run separate cables to each tv.
Sep 05, 2015 | Watches
What can I do, just purchased a watch and is not working properly.
Honestly if it were me, I would simply return it to where it was purchased.
Also know that anything purchased via a credit card is usually protected.
You can call the credit card company and tell them the item is defective. They will ask if you have tried to remedy the situation with the seller, and go from there.
I hope you get your refund. God Bless and Thank you and your husband for your service.
Nov 13, 2014 | Watches
How to touch up a black metal watch strap
i use black nail polish for the chips, cheap and easy
Nov 10, 2012 | Watches
how can i repair scratches on a plastic caravan window
Plastic polish comes in a variety of grits to help buff out scratches in a wide variety of plastics. Novus is a popular brand; their stuff comes in 3 grades: #1 for very fine scratches, #2 for moderate scratches, and #3 for deep / rugged scratches. I generally use #2 polish; #3 polish leaves smaller scratches behind that must be buffed out using #2 polish. Auto repair shops also sell plastic polishes. You might also be able to use automotive rubbing compound, if you don't have access to plastic polish. In a pinch, you can also use traditional white toothpaste, as it contains mild grit (that's how your teeth get polished, after all). Note that toothpaste may also leave behind small scratches.
In terms of hardware, some people use a rotary buffer (like you'd use with car wax) to apply the polishing compound. I have tended to leave swirl marks when I use one. Some people use a Dremel rotary tool, but the super-fast rotational speed can melt/burn the plastic if you apply too much pressure. I prefer to use a soft, all-cotton cloth (an old washcloth or tube sock turned inside out works well), with a dab of polish on it. For straight line linear scratches, I generally run the polish along the scratch to lift out any paint, etc, and to soften the walls of the scratch. This alone usually makes the scratch a lot less visible. However, to finish the buffing, it's good to polish in a circular motion to feather the areas immediately surrounding the scratch into the scratch area.
Some plastics are tougher to polish than others. Super-hardened plastics and some polycarbonates will not clear up using these methods. Most, however, will at least look better after you've done a bit of polishing, even if the scratches don't completely disappear.
May 11, 2011 | Watches
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
Apr 14, 2009 | Seiko SGF204 Wrist Watch
1,420 people viewed this tip
Top Guess Watches Experts
Jimmy Accardi
Dennis Fitzsimmons
Level 1 Expert
Are you a Guess Watch Expert? Answer questions, earn points and help others
