Tip & How-To about Computers & Internet
Dell520, bottom of computer gets very hot.
LAPTOP FAN !!!!!!!!
YES, especially if its on fabic( your carpet/bed) , this can burn up your processor. a hard surface is best. i what i did was bought on laptop fan its flat about in inch high fits my laptop perfect, plugs in with usb cord that comes with fan. now my laptop never gets hot...
Computers & Internet Logo
Can I run laptop for 2days or more continuously? What can I do to avoid any damages that can be caused for long running? Does lowering processor power help?
1) Make SURE the Air Intake Duct has clearance around it, and is unrestricted from blockage.
( It's usually on the bottom of a laptop, with the Exhaust Duct on the side. Some models do have the air intake duct, and the exhaust duct on the side, however )
Although touted as a Laptop, it should not be used directly on your lap.
A flat hard surface of some sort is set on your lap first.
A laptop should Not be set directly on a bed, or couch, or carpet floor.
Always on a hard flat surface.
If your laptop has the air intake duct on the bottom, think about how close it is to the surface the laptop sits on.
Not much.
Air is used to cool the hardware components inside a computer. The air flow must be unrestricted.
(Except for certain high-end gamer desktop computers. They may use a type of cooling that water, or refrigeration, or dry ice, or Nitrogen, may be used)
2) Run for 2 days continuously? If the AC adapter (Charger) is plugged into power, and into the laptop, yes.
Lower Processor power? I wouldn't ,unless this is an indication you are planning on using Battery power only.
Even with the laptop set to Power Saver mode, you won't get two days out of a laptop battery.
(Can I be wrong? Moi? Yes)
It would be an added bonus if you used a Cooling Pad.
This will ensure that the laptop is sitting on a hard flat surface, and will also add additional air for cooling.
There are economical models. Some models use a USB cable that plugs into the laptop, for their power.
Some models run off of batteries that are installed.
Examples from a quick search,
1) http://www.newegg.com/Product/Product.aspx?Item=N82E16834998922
2) http://www.newegg.com/Product/Product.aspx?Item=N82E16834980010
A laptop's enemy is dirt/dust, and heat.
(Also food crumbs, and drinks)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2011 | Computers & Internet
my dell XPSM1530 getting more heated while working what to do
check he heat sink fan working properly or not.
this fan start swinging when more heat generates/
also keep your laptop on hard plane surface while working on it.
never place it over bed like surface. if want to place it over bed.. then first of all place a book, then place the laptop over it.
Sep 28, 2010 | Dell XPS M1530 Laptop
laptop heats and shutdown
You should not use a laptop on a soft surface such as a duvet or bed covering. The device needs to have free air intake and outlet to cool the processor. If you block the intake, which is probably under the machine, it will overheat and shut down.
If you want to use it in bed put it on a hard surface such as a large book, so that the air intake cannot be blocked.
Mar 26, 2010 | Lenovo 3000 Y410 Notebook
overheating
are you leaving it sitting on a fabric surface i.e- pillows. blankets... beds carpet?
also not enough ram, too much going on at one time can do that. Make sure your fan is working properly and maybe download a cpu temperature monitor. google it u should find something
Oct 06, 2009 | Dell Inspiron 1420 Notebook
227 people viewed this tip
David Payne
David Payne
