Tip & How-To about Computers & Internet
LOCK UR CD ROM! Goto >run >type regedit >find allocatecdrom >change d value frm 1 to 0 Done. To reset it to nrmal then type 1 in place of 0.
Computers & Internet Logo
Windows Explorer does not see the drive any more. I put a CD or DVD in and it makes the usual noises, but WE does not show the drive. For example, I put a music CD in and nothing happens.
Hello Sir,
Just follow these steps been provided to restore your CD/DVD ROM drive.
Go to start and Open the run command
Type regedit in the box and run
Then do as follows. Goto
HKEY_LOCAL_MACHINE
\SYSTEM
\CurrentControlSet
\Control
\Class
Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
Value Data: [Delete All Value Data from UpperFilters and LowerFilters]
Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
Exit Registry and Reboot.
Thank You
Aug 09, 2010 | Dell DVD-rom DVD Drive
Ferrari 1100 cd drive wont read oor write
Please try this :
Open the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
[to open the registry, vista or 7, navigate to start, then type in regedit, choose from list, right click and say open as administrator. On XP, navigate to start, choose run, type in regedit and hit enter]
Then find the DVD & CD ROM key under above value.
Under the DVD & CD ROM key, find the values UpperFilter & LowerFilter and delete both seperately. Reboot machine and recheck. See below for picture
May 28, 2010 | Acer Ferrari 3200 Notebook
unable to activate show hidden folders
You are right that this is because of a virus attack. The virus has changed somethign in the registry. Follow the below methods:
Method 1:Go to registry editor by running regedit in the run box.
Go to this key:
HKEY_CURRENT_USER\Software\Microsoft\
Windows\CurrentVersion\Explorer\Advanced
In the right hand area, double click hidden and change the value to 1.
Now you’re all set to go. Check it in your tools menu if the changes have taken effect.
Method 2:1. Click “Start” -> “Run…” (or press Windows key + R)
2. Type “regedit” and click “Ok”.
3. Find the key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\
Advanced\Folder\Hidden\SHOWALL
4. Look at the “CheckedValue” key… This should be a DWORD key. If it isn’t, delete the key.
5. Create a new key called “CheckedValue” as a DWORD (hexadecimal) with a value of 1.
6. The “Show hidden files & folders” check box should now work normally. Enjoy!
Mar 29, 2009 | Microsoft Windows XP Home Edition
Error 1311: source file not found:E\LENOVO3000 Y410 USER GUIDE\VISTA\6.LAN\FILES6~1.cab , Verify that the file exists and that you can access it.
The cause of the error is a problem with the Microsoft® Windows® Installer program used by the software. It produces the error when the registry entry AllocateCDRoms at the following subkey is set to a value of 1.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Warning!
Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft has provided a wealth of critical information you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined in ARTICLE-ID: Q132332 "How to Back Up the Registry" in the Microsoft Knowledge Base. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
Start the Registry Editor and locate the following subkey:
goto start->run and type regedit to start registry editor
Change the value for the AllocateCDRoms entry to 0.
Exit the Registry Editor.
Dec 28, 2008 | Lenovo 3000 Y410 Laptop
windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
203 people viewed this tip
David Payne
David Payne
