Tip & How-To about Computers & Internet
How To Password Protect MS-Word Files? - GoTo: >Tools In MS-Word >OptioN >Security. Then Type Desired PasswOrd..
Computers & Internet Logo
word password removal on ms word 2007
Microsoft Office Word 2007 has a feature that allows Office user to lock, encrypt and password-protect a Word document so that anyone without a password cannot make any change to a Word document. Also you can unlock Word 2007 document at any time with ease.
To unlock a locked Word 2007 document, there are two methods you can choose to unlock word document.
Read More:
http://recoverlostpassword.com/article/unlock-word-2007-document.html
Mar 29, 2011 | Microsoft Office Outlook 2007: Windows
How to Make Invisible Password Protected Folder Submitted by Srikanth on Thursday, 10 December 200930 Comments Do you want to password protect your folder? Do you want to make it invisible so that it remains unnoticed by the normal users? Well here is a way to do that. In this post I will show you how to make a password protected folder in Windows without using any additional software. Here is is step by step procedure to create a password protected folder. How to create a Password Protected Folder Step-1: Create a new folder (Right-click -> New -> Folder) and give it any name of your choice. For instance I name it as ABC. Step-2: Now in this folder place all the important files, documents or any folders that you want to password protect. Step-3: Now Right-click on this folder (ABC) and select the option Send To -> Compressed (zipped) Folder. Step-4: Now a new compressed zipped folder gets created next this folder (ABC) with the same name. Step-5: Double-click on this compressed zipped folder and you should see your original folder (ABC) here. Step-6: Now goto the File menu and select the option Add a password. ie: File -> Add a password Now a small window will pop up and here you can set your desired password. Once the password is set, the folder will ask for the password every time it is opened. Thus you have now created the password protected folder. How to make it Invisible Step-1: Now Right-click on this password protected folder and select Properties. Step-2: At the bottom select the option Hidden and press OK. Now your folder gets invisible (hidden). Step-3: In order to unhide this folder go to My Computer ? >Tools -> Folder options. Switch to View tab, scroll down and under Hidden files and folders you?ll see the following two options Do not show hidden files and folders Show hidden files and folders Now select the second option and press OK. Now the invisible folder becomes visible in it?s location. To access it you need the password. To make it invisible again repeat step -1 through step-3 and select the first option and click OK. Now the folder becomes invisible once again. I hope you like this post. Pass your comments!! Cheers
Mar 30, 2010 | Computers & Internet
Password Protect...I use Vista Home. When I go to save a file. FILE-Save AS the window that comes up has an option of "Save with Password". This option is ghosted out and can not be selected.. I have used it in the past. How can I make it available again?
There are a couple of ways to do this.
Try going to Tools;
Then Options;
Click on security Tabs;
you will see this
Got to Password to Open;
Click Ok;
Fill it in and you will see this;
Re-enter your password;
Click Ok.
Save the file like you normally would.
This should resolve your issue.
Make sure you check your registry for Windows Vista for errors to see if that is causing the problem also.
I am including another link you may be interested in for your IE passwords also.
http://www.watchingthenet.com/enable-internet-explorer-prompting-to-save-passwords.html
Let me know if you need anything further!
Thanks for using Fixya!
KittyTech
Mar 11, 2011 | Computers & Internet
How to protect MS Excel file using password?
In Excel 2007: 1. Click the round Office button in the upper-left corner of the window. 2. Click Prepare, then Encrypt. 3. Enter a password in the list box. 4. Click OK. 5. Re-enter the password. 6. Click OK again. WRITE THIS PASSWORD DOWN. IT'S TOO DARN EASY TO FORGET IT WHEN YOU NEED IT AGAIN. Perhaps Word Password Unlocker can help when you forget the password.
Dec 03, 2009 | Computers & Internet
167 people viewed this tip
David Payne
David Payne
