Tip & How-To about Computers & Internet
Record sound without software
Want to Record Sound In Computer Without Any Software?
Go to Run
Type: Sndrec32
Press Enter
Computers & Internet Logo
my word processing software continues to move the cursor at the wrong time. When typing the cursor will move to the beginning of the previous word. I tried slowing the pointer speed problem still appears. Please advise.
First uninstall world processing software then reinstall from disk. You can uninstall it from start menu->control panel->add remove programs you can also repair it from there. Also speedup the computer wit below method. Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check.
Let me know if you need further assistance. Thanks for using FixYa.
Aug 14, 2010 | Computers & Internet
My Toshiba laptop is very slow at booting up. I have been told that it is because I have approx 130 programs in my start up folder. However, short of turning one off and then rebooting for each application, is there some way of determining which app's can be deleted from my start up file?
For that go to start menu->run or press windows key + R key so you can see run type in "msconfig" then press enter then you can see system configuration utility click on last tab startup and disable all thewn apply and restart then all startup disable. If you want to uninstall any software for that go to start menu->control panel->add remove programs then uninstall software from there as you want . Also follow below procedure to speedup the computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here .Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 06, 2010 | Toshiba Computers & Internet
my windows xp run very slow
Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Jul 19, 2010 | Acer Computers & Internet
Good day, My microphone seems dead, How can I check if the computor is finding the driver or how can I switch it on if it is off thanks joe
[Start],[Run], mmsys.cpl
3:rd tab "Audio"
2:nd Heading "Recording"
1:st button "Volume"
Make sure volume for microphone is at about 50%
and that it is selected.
[Start],[Run], sndrec32.exe
Press record
Make sound in the mic, should get waves on graph.
Playback.
May 09, 2010 | Microsoft Windows XP Professional
Everytime I restart my computer I have to run the connection diagnostics to get access to the internet. I am running windows xp with an AT&T gateway 2 router.
Cut power to the router.
Reconnect it, and let it start-up, for 2 minutes.
Restart your computer.
Click Start
Click Run
Type CMD and press ENTER.
Type IPCONFIG /ALL and press ENTER.
Record the information, e.g., 'IPCONFIG /ALL > temp.txt'
Type IPCONFIG /RENEW and press ENTER.
Better? Worse? Same?
Nov 01, 2009 | 2wire Computers & Internet
184 people viewed this tip
David Payne
David Payne
