Tip & How-To about Computers & Internet
Restore the PC
Want to restore ur pc?
open run
type msconfig
select tool
system restore
next
select a restore point
ok
system will reboot after restore
Computers & Internet Logo
having trouble opening. emails . keep clicking on selected email bjut it either will not open or after 25 tries it will open slowly.
Which email program hotmail ,outlook express , yahoo , gmail ...or are these email attachments or just email
Have you tried right clicking select open ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jul 15, 2013 | Computers & Internet
system boots up but i need to set system
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
Jun 11, 2010 | HP Vectra Xe320 PC Desktop
i lost my prefetch folder. how can i get it back?
1.
2.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, click Next.
4.
5.
6.
Dec 28, 2009 | Microsoft Windows XP Professional for PC
my computer is very slow and there is virus what l have to do?
Go to this site
http://housecall65.trendmicro.com/
and run a full scan - this will remove most of the viruses on your computer. Should help speed it up as well.
Once thats done, install AVG Free and run a full scan
Install for AVG ->http://download.cnet.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html
Once AVG is done scanning, i'd also install and run SpyBot S&D to remove any other infections that AVG/HouseCall may have missed.
Install for SpyBot S&D -> http://download.cnet.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html
After HouseCall, AVG and SpyBot have ran, you should be all set! If you can't get to any IE pages, and are posting this from a different computer, see below on how to restore your IE settings...
Being that you were able to get to this site to post, i can assumeIf you can't seem to get to the site, which happens w/ some viruses, try restoring your internet back to its original state. There's steps on how to do that below as well.
  1. 1: Open up the internet window, by clicking on the "blue e" on your desktop, or by going to the Start Menu, All programs, internet Explorer
  2. Step 3 blue-e-2_thumb.jpg From the Start Menu If the "blue E" is not in fact on your desktop then refer to the picture in this step.
  3. Step 4 toolsmenu_thumb.jpg Menu Bar 2: Once the internet is open, you will then want to go to the "Tools" Menu, in the internet window. If you are using internet explorer 7 the tools menu is on what is called the Menu bar, and this menu bar generally is in the upper left hand corner.
    Picture is attached.
  4. Step 5 internetoptions_thumb.jpg Internet options selection 3: Once you click the Tools Menu, then select, internet options. Image below attached, then click on internet options to go into the internet options dialog box.
  5. Step 6 ioptionsdialogbox_thumb.jpg Advanced Tab 4: Once you have selected the internet options click on the advanced tab all the way to the right, picture attached. Once you have selected, advanced at the bottom right there is an option there to RESET, this will restore the default settings, of your internet explorer Browser.
  6. Step 7 5: Reboot machine.
Also, another thing to consider is a system restore, if your computer is so bad that the above isn't working. For XP, system restore works wonders. See below for instructions on how to complete a system restore.
1.
2.
3.
Figure 2
4.
5.
6.
After reviewing the stability of your system, you can choose another restore point or undo this restoration. Just open System Restore and make the appropriate choice. After you use System Restore, you'll have an additional task, Undo my last restoration, on the System Restore Welcome page. Remember that you'll have to reinstall any programs that were installed after the restore point.
If System Restore doesn't work in Normal Mode, it might work in Safe Mode. To use System Restore in Safe Mode, press the F8 key during reboot and choose Safe Mode. When your computer starts in either Safe Mode or Normal Mode, System Restore can be used to capture a working previous state. System Restore can't be opened unless the system is bootable into one of these modes.
...ok, im running out of breath here!! Hope all this helps - good luck!!
Sep 17, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
my pc hang how solution this problem
Hello Ramkrishnasa,
You are getting this problem not because of ur pendrive as you said that Same problem is occuring even if you are playing audio or video files from HD.
The problem would be occuring because of:
1. missing of codec.sys files that enables ur system to play any video or Audio files.
2. Missing of ur system media *.dll file.
3. It can also be caused due to viruses.
You need not to worry about this thing. Follow the following steps to fixya problem:
1. It is recommended to restore ur system which will fix missing media system files or any error that leads ur system Hang.
2. To Restore ur System: Go to "Start"-> "All Programs" -> "Accessories" -> "System Tools" And then Click "System Restore".
3. You'll be able to see the wizard to restore ur system.
4. Now select the redio button to choose different restore point.
5. Select the restore point, you suspect that ur system was functioning well at that point. You can select different resotre point by scrolling the calender.
6. select the restore point and click Next to restore ur system.
7. System will restart automatically to restore ur sytem.
Thanx
-Romy
Aug 02, 2008 | Microsoft Windows 98 for PC
175 people viewed this tip
David Payne
David Payne
